Muller Dynamo
0 Members and 89 Guests are viewing this topic.
Magluvin
Hifi?  lol   hey Bruce, what is your coil, fityfi?   lol
I got my self laughing after my last post with this, and I had to post it, no harm intended, just chuckles.  ;]
Magfi
e2matrix
Mags,  LOL  you need some sleep :)   I may too but I think if you got one coil set that's getting 3.3 watts then seven coil sets will get you 23.1 watts.  Right?  Like I was saying wiring all seven coils sets in parallel will give same voltage but will bring the current back up as in x 7.
e2matrix
Quote from: Dave45 on June 29, 2011, 09:41:51 PM
cool video ,  so if the high voltage coil (regenerative coil) stores energy inside couldnt we wrap the coil with Mylar in between the windings and increase its capacitance
is this what Lasersabre did with his coils
I'm not sure if that's what Lasersaber did but I think konehead mentioned using Teflon tape between each row of windings although I don't know if it was his intention to increase capacitance.  I think he was doing it to protect the lower grade Litz (with less enamel on the wire) from shorting out to adjacent windings.
konehead
Gary:
I was saying to adust te airgap between the upper and lower coils and the rotor magnets to be "offset' such as for example 4mm at top and 1mm at bottom, and then see if you can delay the current compared to votlage so that you can hit the max voltage/miminum current resonate thing by hainve the coil sin paralell or series...
Baroutotlogas:
I got the DRIVE coil to have half the draw with magnet on back of it at least.
Jason O:
yes like Gary said drill out the plastic on back of coil and slip magnet in there. The drive coil should  run with less draw so that is good.
Hope you can get something to happen with the series cancelling experiments if that works we are home free...
Magluvin
Quote from: e2matrix on June 30, 2011, 12:24:07 AM
Hey E
I thought about that, but was thinking if it is just one set at a time, that is 3.3 over a period of time, not all together. And with a 20w bulb sucking away continuously, I dunno.  But, I wont dismiss some magic here that calculations dont fit.  I really hope so.  ;]
Ya know, I dont know if you remember Zeropoint321, with the self running no bearing bedini style motor, but it was bifi and his vids with the schematics got shut down, Actually the told him not asked to take them down. but he could still post vids without the shematic.  It was a 4000 turn bifi, reed, 2 diodes, led and a 10uf cap. Spin it and it went. he still has the vid without the schematic up I believe.
later on, we talked for some time, he did some experiments on multifilar coils. he showed a comparison from 2 strands, 3 strands and 4.  The more he had, the further a magnet was pushed away from the coil, all ran from the same source.  he was building a motor gen sorta like what we see here. But then I didnt hear from him for a while.
I had just talked to him recently and he said he had a mild stoke.  Sucks. He is a good guy. Hopefully no one did that TO him because of what he was showing.  =[
Ok  i gottttta git. catch ya tomorrow.
Magfi
