Muller Dynamo
0 Members and 51 Guests are viewing this topic.
Dave45
Ok Im going to get out there on this one,   ;D
What is lenz - say there are two fields in a magnetic field one moveing one direction and one opposite,
Leedskalnin said we only use one pole that we didnt use the positive pole
So if we are collecting only one pole, then is lenz the other pole circulating in the coil causing drag,  and can it be collected also?
also in Ramero's rig he used shielded wire returning to his battery   why?
There's a vid out there that uses a iron coil and the bemf collected is run to the opposite side of the battery than a normal copper coil.   interesting no
auhh the possibility's are endless
its an awesome creation
David70
@Chef
Are you sure that the picture you posted is not altered?
Let's say that  one is fake but then must answer how in the first video the amps is not going up if he connected the bulb to the battery? the amps are going down....???? ???
Let's find a solution for the suspended one too.
Where is that guy who had another video, can you please post it?
Regards,
David
Dave45
Quote from: David70 on July 02, 2011, 09:21:11 AM
@Chef
Regards,
David
I agree where's the other vid that was referenced by Ramero.
Inquiring minds want to know    :D
Artist_Guy
@Chef
Are you sure that the picture you posted is not altered? (snipped)
There is no trickery in any image posted. I created that picture (as can anyone else) from actual HD video screenshots at the times stated and posted it on OUR's forum, because critical comments are not as welcome on this forum (they have disappeared generally). It was reposted without asking here, though I don't mind so much if it illuminates the discussion. Gamma changes only brighten the darker areas, they don't create more information (certain compression artifacts excepted, however they are not a factor here). Even without the contour lighting added, one can see there is the suggestion (to put it lightly) of a problem.
I don't know about Video 3, I've looked at it a lot. Video 1 ran off a battery.
But in Video 2, wires are seen where there should not be any, and in Video 3, there is no lamp, for a device said to have been built to match a 25 watt load, and to require that load to work (presumably other than itself). Such makes sense if small batteries are running the works.
My belief is that if something truly works, it can be replicated. It is not a matter of ether waves or trans-luminal semi-conductance, nor intelligent implementation of a turbo-encabulator using Thane-wave distortion modules.
If it did actually work however, and was 'repressed', the inventor can now be considered to be an active and completely voluntary participant now -as to that repression-. Any patent issues would have been solved by C&D letter, followed by a court case if that didn't work, not a visit by confiscatory agents of evil. Cure for the latter is plenty of light of disclosure and a police report.
I think Romero seems honest about his visit, so possibility was an exaggeration of real results (the big mistake), getting out of hand once domain information was posted followed by an unwelcome real visit perhaps, by those unhappy to find out it was not as it was stated, or maybe they weren't told even then. Who can know.
AG
Jdo300
To all those doing actual experiments:
I would like to know if anyone has seen a speedup effect with the output winding connected with a series capacitance vs. a parallel capacitance. So far my experiments have shown that when a series capacitance is driven at resonance, the current at resonance amplifies the drag force, but in parallel, the opposite occurs. Would those of you who have done such tests please share your notes?
As much as I'm enjoying the theoretical discussions here, I would much prefer to focus more on test results and hard data.
NOTE: For those who missed them, I posted a video link to my latest experiment showing the speedup effect in parallel resonance:
http://www.overunity.com/index.php?topic=3842.msg293548#msg293548
- Jason O
