Muller Dynamo
0 Members and 47 Guests are viewing this topic.
aircore
    From the beginning of the high replication all enthusiasm, To the present mess speculation and experiment, We are still not good progress,
    With my observations: Many people have given up replication, Including: "CLaNZeR", "Lidmotor", "lasersaber" other,,,,,, "skycollection" never involved in replication, I think there should be a reason.
    This thread is really close to death.
    This is just a wonderful fantasy and unreal dreams.
    In fact: "Lidmotor" video has hinted us a lot.
    http://www.youtube.com/watch?v=QP8ucCA-jP8&feature=mfu_in_order&list=UL
Thaelin
  Well then Mr. Aircore, explain then the vid that Lidmotor just posted???
Looks like it was running on ok. Allbeit made to run on 1.5v instead of 12.
Then we all saw the RUK machine running while being toted all over the place
and kept on going. There was another, he was beat on too and left. What will
it take ? If you have no interest then sit back and enjoy the ride while we
continue our quest.
thay
bolt
Quote from: aircore on July 03, 2011, 08:56:50 AM
    Now we really need cool-headed and sober.
    Why replication success so far no one?
    Because: RomeroUK device is indeed false. And: We overestimated RomeroUK,
    "konehead", "bolt" describes many of the theories, RomeroUK may simply not understand.
    Please plengo not edit my speech, Because I speak for all of us are good. In order not to waste your energy and money.
This thread is not for discussing fakes its for discussing replications and theories about the Romero Muller. If you doubt it then discuss it on other threads to which there are several. The fact no one has achieved a perfect OU replication does NOT make it a fake just some information maybe misunderstood. No different to Kapanadze or the TPU etc.
bolt
itsu
OK guys,  as promised, here a video of serial resonance testing:  http://www.youtube.com/watch?v=K-avee5Z1oU
I used the same hardware as with my parallel resonance testing, but with totally different results like also Jdo300 already pointed out.
Coil is multi filar (6 strands 24 AWG) in series, 27mH / 8.7 Ohm
Capacitor is 40uF non polarized,
resonance to be calculated and found to be right is around 160Hz.
As we have in serial resonance a minimum impedance (like almost shorted), a perfect resonance sine waveform for both Voltage
and current appeared only when shorting the circuit BEFORE the FWBR (seems logical).
Shorting BEHIND the FWBR still shows some sine waveform, but voltage is more distorted (i guess the nonlinear diodes messing this up, right?).
Opening the circuit shows a "normal" voltage (no current offcource) you can expect when a magnet is passing a coil, no sign of
a resonance sine wave!
I guess this opening of the circuit destroys the resonance completely.
When putting a load (28 leds brakelight) on it, it completely distorts the voltage waveform, and i fail to see any phase shift (allthought it is hard to see with this clamped off voltage waveform).
So, no speed up under short/load like seen with parallel resonance.
To be continued,  regards Itsu
