Muller Dynamo
0 Members and 279 Guests are viewing this topic.
FreeEnergyInfo
Quote from: Dave45 on July 03, 2011, 08:55:48 AM
Cool you found it, I wanted to paste it but couldnt find it besides the vid
FREE DOWLOAD ....
http://depositfiles.com/ru/files/l0njcj24c
FreeEnergyInfo
Quote from: aircore on July 03, 2011, 09:27:44 AM
    From the beginning of the high replication all enthusiasm, To the present mess speculation and experiment, We are still not good progress,
    With my observations: Many people have given up replication, Including: "CLaNZeR", "Lidmotor", "lasersaber" other,,,,,, "skycollection" never involved in replication, I think there should be a reason.
    This thread is really close to death.
    This is just a wonderful fantasy and unreal dreams.
    In fact: "Lidmotor" video has hinted us a lot.
    http://www.youtube.com/watch?v=QP8ucCA-jP8&feature=mfu_in_order&list=UL
VIEV...
http://www.youtube.com/watch?v=ch2YYJorB5Y
Rawbush
So, last night I made a mold to make magnetite/epoxy cores. The cores are 3/8" dia and about 1 5/8" long when they come out, may trim down. I am starting with two for testing.
The coils I was using (from automotive relays) only produces about 5 volts at motor free run speed of 1750ish rpm. I unwound one coil folded the wire in half to get two wires that were about 115 foot each and rewound the same coil bobbin bi-filer, the result was the same 5 volts. The only difference I seen with the bi-filer is that by adding a bias magnet I would see up to one volt increase on the scope, I was unable to get the same effect with the single wire coil. So my thoughts are that to get the required voltage I need 3 times the wire ( almost 700 feet worth). So I have unwound 7 relay coils for the wire and will be using it for new coils. My plan is to make one coil a single wire coil, but will splice three wires together (series) to get the 700 feet for coil one. Coil two will be three wires twisted (parallel) tri-filer, so there will be the same amount of wire (mass) on both.  Off to the garage, will post results as I get them. Peace
rawbush
konehead
Hi Dave45
in question aout what is lenz law, what we are dealing with is "rotational" lenz law (lugging) using magnets going past coils and cores.
so what happens is if magnet is Ntop-Sbottom going past the upper coil/core for instance, that upper core, and the coil too, (coil "following" the core's polarity) will become:
Stop-Nbottom....so that the core will want to stick to the magnet - thats how it will polarize.
and when rotor magnet rotates AWAY from this coil and core that wants to stick to it, it will want to pull that rotor magnet back to itself, and that is waht causes all tha textra draw and slow-down to the rotor....and more power you make, the more the rotor wants to get pulled backwards too.
thats what the magnet behind cores are for - they will re-polarize ("regauge) the core so that it will give push to the rotor, instead of pull-back and extra draw.
since dealing with rotating thing here, the faster it goes, the more power you make and vice versa...so getting any sort of rotational speed up makes for also more power made in coils so when you do get past lenz-lugging things will accelrate in power "non-linear" is my theory on that.
One other way to get around the whole lenz-lugging thing is to simply SHORT for very short blip in time, the coils into caps.
Dont do a continuous dead-short, but just a very quick one, only at the sinewave peak-period of the coil's waveform as seen on scope.
A few guys have done videos showing this will not affect draw - but only when you find the right timing...
so now you have stored power made from the coils without affecting draw.
Once the power is in caps, now release it into the load.
Disconnect the coils filling the caps from the caps WHEN caps do hit load... (same thing you should do with colleciting backemf from motor coils into caps)
Now the coils only have to fill up caps tha tis only time it will ever see a load - and it is doing this via a "shorted" condition too...we know that shorting staggers the current from the votlage - its max current mimimum voltage druing short, and on opening of swtihc, its maximum moltage and minimum current...the opening of swtihc is what fill up capacitor without any lug to rotor.
because capacitor hits load when cap is disconnected from coils so there is no lugging to coils during whole sequenc of events what else can you ask for.
There ar plenty of videos now on youtube doing simple coil shorting with reed switches and complicted circuits too, on youtube if you think it doesnt work watch them and then try it on your romero replications.\
Only limitations is how fast can you fill the cpa, and how fast can you dump to load and how big of a load and how big of caps can you fill....thats where you want improevements and more effeciency...
e2matrix
Warning: Post contains NO info relative to building this project.
Quote from: aircore on July 03, 2011, 08:56:50 AM
    Now we really need cool-headed and sober.
    Why replication success so far no one?
    Because: RomeroUK device is indeed false. And: We overestimated RomeroUK,
    "konehead", "bolt" describes many of the theories, RomeroUK may simply not understand.
    Please plengo not edit my speech, Because I speak for all of us are good. In order not to waste your energy and money.
That's funny.  Back on page 200 on June 15th  you said: "   Because there is no substantive breakthrough and progress, it seems many people have chosen to forgo.
    This thread is close to death."
We are now on page 269.  Your predictions are wrong and your agenda obvious.  Beside progress in a number of areas I suspect many here are not full time researchers/builders.  I haven't even wound a single coil yet but I will give this a try as time and money allow.  Regardless of outcome it's a great learning project.  However I strongly believe success will be had at some point.  There may even already be some but those with success may not want to deal with a situation like Romerouk had.
