Muller Dynamo
0 Members and 260 Guests are viewing this topic.
freenergy850
Quote from: e2matrix on July 05, 2011, 12:37:34 PM
He has worked on a lot of projects.  It could be a TPU unless this is a new pic as I think he was working on that for a while.  I think there was also some mention of trying the Muller effect in a solid state concept.
Pic is dated 7/1/2011...
teslaalset
Quote from: David70 on July 05, 2011, 09:12:29 AM
I have copied this picture from Romero's website, anyone any ideea what that is for?
Can someone post the link to his website, please?
konehead
Hey Arthur
You sure make nice graphics -
as for the mtoor coils, what is happening pretty sure, is yes, one coil works fine, but two in sieres cuts down the ohms in half, so you have half the draw and half the speed...probably not half the draw acutally, since this is rotating magnet rotor, and at lower speeds its harder to keep spinning but you do get half the speed...this is the "correct way" to hook motor coil in series,
in third illustration, you have the coils in series, but "series cancelling' and no magnetic field happens at all and thats what you got.
This third way is what Bolt is recommending and Jason and Itseu have tested out with the GENERATOR coils hooked up like that...then you do some cap-tricks to shove the current out of phase from the voltage and then you can get power rinto caps and also doing it in non-lugging fashion.
Jason has the good suggestions either go with higher voltage, or run the two motor coils in paralell...when you get the 2nd coil pair woking as motor coils you will really have some good power - you might want to decide final hookups if series or paralell at that stage, since it might be you want less draw not so much power (series) or max draw max power (paraelell)
Just hold rotor with magnet lined up TDC to coil and connect coil leads to battery direct very briefly, to see which way it spins  when coil energizes to find out the polarities to the coils... so just make sure one coil doesnt push it backwards and the other forward...
wings
darkwanderer
This can be the toroid for more powerful dc-dc converter...
