Muller Dynamo
0 Members and 31 Guests are viewing this topic.
yssuraxu_697
Quote from: Groundloop on May 08, 2011, 03:49:56 PMI have air core coils in my Muller and it does NOT give out any free energy. I think the smartest thing to do is to replicate romerouk's setup.
Ok, good to know. Of course first thing would be 1:1 replications not to mess things up. If it should work I would go for same diameter cores/magnets and big core material volume. I have seen pretty crazy scope shots and stuff with my pulse motor with massively oversized ferrite core (compared to neo magnets on the rotor) so it may be indeed that core material is "the source" when handled in clever ways.
gyulasun
Hi Romero,
I think you can reduce the input current draw for the Hall switch + the TIP42C by inserting a series resistor between Pin 3 of the Hall and the base of the TIP42.  As it is shown in the schematic
( http://www.overunity.com/index.php?action=dlattach;topic=3842.0;attach=52576 )
Pin 3 is an open collector and directly connected to the +12V via the base-emitter junction of the transistor, there is no any current limiting for the junction and for the inside Hall switching transistor.
I do realize that your circuit works as it is shown  but I guess at least a 30 - 40mA current draw could be saved per one TIP42C by inserting a 680 Ohm to 1 kOhm resistor between Pin 3 and the base electrode while the switching would take place still safely, for both TIP42s.
What do you think? perhaps you have considered and tried this?
Thanks,  Gyula
romerouk
Hi,
most of the questions have answers already, please read all posts... I am tired to just answer same questions hundreds of times.
The coils are 1cm usable, the inside between the ends, in total 1.2cm and diameter 2.2cm
the core ferrite 1.5cm/6mm diameter.
I have tried without cores but less performance, higher speed but low output.
I will not do other videos, this way, everyday I will find someone to suggest something else.
For all replicators.
After some tests today and changed one pair of coils, same type of wire but 1.5cm diameter ferrite core, 1.5cm long.
Still 1cm winding space on the coil on 3.5cm diameter coil.I have doubled the number of turns to 600 for each coil.
This was done just for one pair of coils, recovery not driver coils.
The output is increased  but for more I will need to change them all to balance the system but  I wont do that, is to much unnecessary work, I wanted to check and apply to the new system.
Don't even think of using metal or laminations for the cores.
I had another request to sell it. I HAVE NO INTENTIONS TO SELL IT. - please no more.
romerouk
Quote from: gyulasun on May 08, 2011, 04:09:25 PM
Hi Romero,
Thanks,  Gyula
Hi Gyula,
I have analysed some other circuits using mosfets and I will consider your sugestion too but for my next build.This one can stay as is.
Thank you,
Romero
FreeEnergyInfo
