Muller Dynamo
Free.Energy
Great work Romero!
Does the rotor spin up a little faster after you have run it for a little time?
e2matrix
Quote from: romerouk on May 08, 2011, 04:17:58 PM
Hi,
most of the questions have answers already, please read all posts... I am tired to just answer same questions hundreds of times.
The coils are 1cm usable, the inside between the ends, in total 1.2cm and diameter 2.2cm
the core ferrite 1.5cm/6mm diameter.
I have tried without cores but less performance, higher speed but low output.
I will not do other videos, this way, everyday I will find someone to suggest something else.
For all replicators.
After some tests today and changed one pair of coils, same type of wire but 1.5cm diameter ferrite core, 1.5cm long.
Still 1cm winding space on the coil on 3.5cm diameter coil.I have doubled the number of turns to 600 for each coil.
This was done just for one pair of coils, recovery not driver coils.
The output is increased  but for more I will need to change them all to balance the system but  I wont do that, is to much unnecessary work, I wanted to check and apply to the new system.
Don't even think of using metal or laminations for the cores.
I had another request to sell it. I HAVE NO INTENTIONS TO SELL IT. - please no more.
Romero,  I totally agree with you on those requesting more video's for proof like disassembling the DC converter.  You will never satisfy such people and they are just wasting your time.  Don't let them drag you down with this nonsense.  Those who know your work know you are not trying to fool anyone.  And anyone with common sense would know that since you are not asking for money and won't even consider selling your motor as well as the fact you are doing everything possible to help everyone replicate this that there is no possible reason you would be fooling people.  If you were it would only make you look bad and would accomplish nothing positive for you or anyone.  So people please consider all that has been given and know that the only real proof will be you building a replication and doing the work of tuning it properly if it does not work the first time you fire it up.
neptune
Romerouk has revealed that cores with a 15 mm diameter not only work but work better . There is hope for us radio ferrite boys .Note extra turns .
romerouk
Quote from: Groundloop on May 08, 2011, 03:49:56 PM
I have air core coils in my Muller and it does NOT give out any free energy.
I think the smartest thing to do is to replicate romerouk's setup.
GL.
Special for Groundloop and the others helping with drawings and info
To get to the point where you will get even a little bit out than in requires a lot of time and work. Check every part of the system, part by part, then when you think is tuned start again.
Let me give u an example:
If u have 10 parts in your system and after jumping from testing  the first then second up to 10, when u finished you start again. It can be that part 3 is not as before after u adjusted any other part after. Once you retried everything and got best of all adjustments then you are nearly there.
Do all this testings without having the rectifiers connected together.Measure every coil separately. Even if you don't get too much out from the coils, don't worry, when all are connected things will go magic.
A DC/DC Converter is a must.
Don't rush, I have spent about a month to get here.
Once u past the point and for 1 you get even 1.1 then things are easy
Success!
Cherryman
As of limited resources and tools
i came up with a simplified version of the construction
Although i fully understand it is not an exact replication, i will use it as the basic starting plan for my built.
I share it, not sure if it would distract, if so, it can be replaced by a mod.
