Muller Dynamo
0 Members and 251 Guests are viewing this topic.
Dave45
Something that has me bugged, why rectify the current
when the ac is run through the bridge you lose half your volts
just doesn't make sense
I was wondering did the old vacuum rectifiers lose half their voltage.
So you make a generator that produces ac rectify the current, lose half what you
produced, put that into a battery, invert that back to ac with more loses  ???
bolt
Diode bridge only lose about a volt not sure how that translate to half? Tube lose a couple of volts also but who cares when tubes usually rectifying 300v rails. I used to have a lovely pentode i ran it on 55kv size of a pint glass. At 1 Mhz it used to go ultraviolet around the outside for 18 inches with a pink haze between the plates! More radiation came out of that thing than Fukushima. :)
scratchrobot
Quote from: bolt on July 13, 2011, 08:56:02 AM
His concept is valid as RLC leads to OU but the ZPE algorithm is over optimistic. It is very unlikely to self run in the manor he describes without an EXCITER.  Like Romero Muller requires pulse drivers to maintain the rpm in narrow band OU. In solid state requires a KICKER coil to maintain oscillations as Kapandze, SR, Ismael MEG, looped Bedini window motors and many others. HV DC pulses can be used as an EXCITER.  Cores of ferrite and iron powder magnify the ZPE by many thousands as core acts as a ZPE  proxy as SR device.  Air cores can work but much lower efficiency as Ismaeal MEG uses two Tesla pancakes wound to cancel out self inductance hit with hundreds of volts pulses then shorted sine peaks and multiplexed. COP 2.7.
Romero Muller must have perfectly NULLED inductance using such method as bifilar wound, out of phase pairs, tuned C's to force into VARS or combination of effects on the generator coils to be discovered on the bench.  Its vital no in phase currents are generated.  System to be tuned into LOAD at required frequency (RPM). Passing neo changes the inductance creates NULL offsets via magnetic modulation to produce a current SPIKES seen as classic romero waveform where most of the energy is compressed as TENSOR along zero point line increases ambient electron Kinetic energy.
Thanks for that explanation, do you think it is possible to create the right conditions only by positioning 2 normal coils at the right position and maybe use extra magnets on the coil to create the out of fase or do you think Romero wound special coils on the muller? And what about the FWBR? Do you think it has something to do with the effect?
I think this even magnet and odd coil setup is also a big leap forward to OU, when perfectly balanced there should be no magnetic drag on the rotor but the magnetic field is moving?
What if you would unbalance the system by switching or putting on a load at the right time, maybe a simple Bedini circuit or some reeds can make it OU. Many things to try!
Bill Muller and also Romero quoted that the Magnets are the motor.
scratchrobot
Quote from: mondrasek on July 13, 2011, 08:51:09 AM
What type core material do you have?  Does it protrude from the coil ends at all?
Mine are type 33, 1/4 in dia. x 1 in long.  When inserted into the coils to match them at 1.2 mH they stick out about 1mm on the rotor facing side.  The back end has ~12mm sticking out.
Romero used cores he took out of PC powersuplies. I have them also but not enough so I bought some but they are different material.
Rawbush
I have finished making 10 coils on sewing bobbins to test a whole set up. Eight are identical 200ish turns (28') of 24 ga., The other coil set is made from 5 twisted 36 ga.(60' each) wires. All fill the same amount of area on the bobbins. I have cleaned a batch of magnetite ( a bit of other stuff), and will be mixing again with epoxy. My question is I will be pre polarizing the magnetite while it dries I wounder witch direction I should polarize it (attraction/ repulsion)? I have thought of reasons for either way but wanted to hear what others think.
Peace
rawbush
