Muller Dynamo
0 Members and 52 Guests are viewing this topic.
hartiberlin
Hi All,
I just compiled Version 1.1 of the PDF file describing the RomeroUK selfrunning device
in detail.
http://www.overunity.com/index.php?action=downloads;sa=downfile&id=471
Enjoy !
Regards, Stefan.
duff
Quote from: hartiberlin on May 08, 2011, 10:10:03 PM
Hi All,
in detail.
Enjoy !
Regards, Stefan.
Stefan,
There seems to be a problem here.
I am logged in and in spite of that when I click on the link it presents me with a login dialogue box.
You are not allowed to view the Downloads
Please login below or register an account ::)
e2matrix
Thanks Stefan!  That will help a lot of people.  I know this thing about the Litz wire keeps coming up so I really really hate to ask this.  Not being in the U.K. I would not want to buy from Romero's source so I was looking at other places BUT I keep seeing that diagram someone uploaded and it's in your PDF compilation of the 7 x 0.125 mm wire.  Here is the problem and to me it looks like a typo.  Seven 0.125 mm wires in a bundle as shown in that diagram would have an overall diameter of 0.375 mm but the diagram shows an overall of 0.875 mm.  A 3 and 8 look a lot alike at a glance so I'm fairly sure that what you have there as 0.875 mm should actually be 0.375 mm overall diameter which for U.S. people is about 27 or 26 guage wire.  Otherwise we are looking at about 19 or 20 guage wire which is a big difference in size.  I'm fairly sure at this point it should be the 0.375mm or about 26 guage for U.S. builders.
e2matrix
duff,  do you have cookies on and do you choose 'login forever'?  If not try that.  I just downloaded it no problems.
mikestocks2006
Just a quick comment on using an external high efficiency motor vs the two drive coils.
While the external motor idea sounds great and it may actually work, at this point we do not know if the two drive coils also contribute to the overall system power generating performance. It is a fully dynamic system with fixed strength fields (magnets), rising and collapsing induced fields (power generation coils), and impulse externally driven fields (drive coils) all those are happening at high speed and with close proximity to each other, most likely superimposing and effecting each other.
I’ll echo what many have already written: a true replica should be as close if not identical to the original. Establish a working base line, and work from there. Because if it doesn’t work, how would you know if it is the principle or the modification/deviation from the original setup shown by romerouk?
As romerouk noted many times, small things seem to make a huge difference.
@ romerouk and all involved, great work
Thanks for taking the time to post and answer so many questions.
Mike
