Muller Dynamo
0 Members and 273 Guests are viewing this topic.
scratchrobot
Quote from: mondrasek on July 21, 2011, 03:11:06 PM
How are you comparing the two?  Were they matched by inductance or wire length?  Was the bottom one mounted with the coil exactly the same distance from the rotor or by initial output voltage levels?
The setup and coils are exactly the same as in my previous test. The coils are made of litz wire so I split the wires and made a bifilar out of them. In essence I doubled the wire length.
Page 300 :)
xenomorphlabs
Quote from: scratchrobot on July 21, 2011, 03:39:54 PM
Would you possibly share your measurement data, so that it is possible to get an idea about the amount of improvement?
Thanks
Arthurs
Page 300 :)
Hi scratchrobot
    When you test a longer duration as possible, You will find: When the output voltage rise time, It was short-lived. Because: speed will fall, Continue to maintain,,,,,,, Speed ​​continued to decline, Finally, the output voltage will disappear.
chalamadad
Quote from: Arthurs on July 21, 2011, 04:52:17 PM
Hi scratchrobot
This is true only if the coils are regular generator coils. If setup in a matter where it is possible to extract energy by displacement current there will be no speed decline and you get extra power out. Your mind is limited to a certain extent unfortunately that is why you are referencing a conventional generator which is not what we want to achieve.
chalamadad
Quote from: xenomorphlabs on July 21, 2011, 10:11:49 AM
Have you considered Mu-Metal?
The effect should however manifest itself with "ordinary" ferrite as Romero did use ferrite and disadvised using steel or laminate.
No, I havn't and I won't for now because as I've said - I want to stick to the original build as close as possible. And with a higher coercivity you will probably get more power out.
