Muller Dynamo
Magluvin
Quote from: mariuscivic on August 18, 2011, 08:02:57 PM
Hi guys!  :)
Nice work everyone!!!
I try to keep it simple: http://www.youtube.com/watch?v=YL90Nmea0Mk
Hey Marius
If you remove the bolt away from the rotor, does it speed up also?
Just thinking.
The bolt could be adding drag, and the coil helps to reverse the drag situation. As in making the rotors attraction to the bolt(core) go away.  Not that im finding fault. I like what you have shown. But, is it the drag situation that I described?
And is there a difference in speedup if the bolt is removed as compared to shorting the coil?
Also, ;]  is what we are seeing speed(freq) dependent?
Very cool stuff.  There is another vid you did a bit ago that I have to go and see it again to remember the question I had for you , but didnt get to it then.
As it seems that the coil needs near 1 ohm or lower, maybe try a small dc motor. Coil to bridge, bridge to cap, cap to motor.  The low ohm of the motor will keep the cap low enough to be seen as a load(near empty) and the cap will help to drive the motor.  You can try the bridge direct to the motor(pulsy) but the cap will help.
Awesome work.  ;]
Mags
Magluvin
Hmm,   wonder if it need to be shorted continuously?   Like the orbo, rotor magnet attracted to stator core (bolt), then short the coil just before or at tdc.  Will it run without the other drive coils?  ;]
Mags
DimaWari
Thanks for sharing this effect.. It is very similar to Adams Motor.
http://www.totallyamped.net/adams/
Page 8
Magluvin
Quote from: DimaWari on August 18, 2011, 10:34:52 PM
http://www.totallyamped.net/adams/... page 8
Very cool Dim.   ;]
Ive never seen this.  But it answers most of my previous questions.  Hmmm  I gotta try this.
Thanks   ;]
Mags
Magluvin
Here is the correction to Dim's link
Then click page 8
Mags
