Muller Dynamo
0 Members and 46 Guests are viewing this topic.
DreamThinkBuild
Hi Prof. Jones,
It looks almost like a flywheel based system, using a gyroscope rotor(?) for the mass. Much like the compensated pulsed alternators NASA is working with.
http://en.wikipedia.org/wiki/Compulsator
It is going to cost initial energy to get it up to speed, which he uses a Dremel,  but once started all you need is little kicks on the diametric magnet to keep the flywheel going.
T-1000
Quote from: FreeEnergyInfo on August 22, 2011, 11:13:07 AM
http://www.youtube.com/watch?v=U8AC8T5cvm4
On 6:10 instead of battery it needs to put DC/DC converter then see if closed loop system can at least sustain itself after kick in... ;)
In another hand, the very short pulse coming into driving coil and long pulse coming out of generator coil ->looped into input is most interesting part on this type of motor/generator...
Cheers!
FreeEnergyInfo
Quote from: T-1000 on August 22, 2011, 02:30:46 PM
Cheers!
VIDEO http://www.youtube.com/watch?v=U8AC8T5cvm4 ==VIDEO1 + VIDEO2
ORGYNAL VIDEO http://www.youtube.com/watch?v=gECwKzRw-gs + http://www.youtube.com/watch?v=H0Awqk9zOjw === MY VIDEO http://www.youtube.com/watch?v=U8AC8T5cvm4
On 6:10 instead == 2 VIDEO .....
T-1000
Quote from: FreeEnergyInfo on August 22, 2011, 02:35:47 PM
Your compilation creates some confusion as motor/generator looks almost same in both videos :) in 1st as far as it show, doesn't run on battery on second - battery is  inside of motor...
freenergy850
Something interesting?...
Today i attempted to use the bemf from the drive coil to try and reduce input current as described on totallyamped.net. The drive circuit i'm using is the one from that site, page 3 fig. 7. I hooked up the fly back path as shown but it really didn't reduce the input current. It does fill the cap to 110v. So i decided to also hook up a small bulb across the cap and it caused the motor to accellerate with no increase in input current, bulb fully lit. Current went down due to the speed increase. The bulb is a small led bulb that contains 4 leds. I did the same to the second drive coil and it also caused accelleration.
I don't understand why, can anyone explain this for me? I was just attempting to use the back emf and end up with accelleration!????
