Muller Dynamo
0 Members and 315 Guests are viewing this topic.
konehead
hi mariusivic
I will bet alot of this effects you are gtting is because of the reed swtich doing the swtiching - they are fickle little guys, and they blow up easily as you probably know, and for instance when you disconnect that LED the draw to the motor coil goes WAY up on the video - for awhile - and that is probably the bakcemf arcing and so forth inside the reed since it was running smoothly when LED was lit, but suddenly return the backemf to the swtich and its arcing inside there - there is jsut small bit of ferrous metal vibrating back and forth in that reed inside nitiogen filled glass tube and when it gets out of synch in the vibrations, like from some backemf/opposite magnetic field/arcing/plasma/carbon deposits/etc etc in that reed it creates false-triggerings and all that - besides the fact there are actually TWO triggers per magnet-pass with a reed...
anywasy you've done good so far that is for sure but I dont think those reeds are too practical since they dont last very long if you leave it running day and night probalby a week or so it will blow up - and if you DONT have any way for the back emf to exit - like your LED they proalby will last only couple days at best if running it like that...I would swtichover to mosfet-swtiching at this point - you've proven the point that when take out backemf, you can make motor run faster and better with reeds now try and doit with some reliable swtiching...but maybe not - my advice might not be good on this subject your doning good but its jsut that I have blown up probalby 200 reed swtiches if not more, over the years and jsut dont use them anymore got tired of it -
so maybe better to jsut stick with what you got and cover ervey angle you possible can and then move on into somethign practical from what you gathered...
I know for fact from FCC engineer that the US govenment has reed swtiches that will work up to 400amps input (!)but they are not allowed to be sold to, or seen by. the public...interesting eh....mabye in nukes or flying saucers they use them who knows...
Overschuss
Hi All,
i can't get the speed-up with loaded BEMF effect, as described by MariusCivic, perhaps because i'm using a Hall-Sensor and a MOS-FET, don't know. But when i hook up the BEMF from my Motor-Circuit (with a Diode) to the loaded Output from my Pick-up Coils (after FWBRs), the Rotor-Speed goes up drastically and the Input-Power goes slightly down.
Nice Effect - and brings a lot of Power. :)
It seems, the BEMF is pretty obstructive for the Motor-Puls Control.
BTW: If anyone is searching for good Iron-Powder- or Ferrite-Cores, try this Website:
http://www.spulen.com/shop/index.php?cPath=41_128&language=en
http://www.spulen.com/shop/index.php?cPath=41_48_215
gotoluc
Quote from: Overschuss on August 27, 2011, 03:56:42 PM
Hi All,
Nice Overschuss,
this is what is needed. Play around with diodes as Romero said you can do amazing things with diodes.
Your generator coil is now assisting in driving the rotor. Try moving its position to see if there's a better timing position. Also, bring it closer or away from the rotor to see what that does.
Please do a video if you can and thanks for sharing
Luc
sinergicus
I think will be a good ideea to implement in moto generators design , some discoveries that are around on the internet ,to eliminate the lenz effect completely...more cheap and easy to construct  the device...
In this direction I want to bring in your attention the reardon lenzless generator..
http://www.free-energy-info.co.uk/Appendix1.pdf  at page 196....
Because my first language is not english ,I have difficulty  to understand  all the patent.... :-[
Regarding red switches that burning out, is possible to self made  robust red switches that will not burning out easy ....
Another idea what I want to suggest is Ossie callanan oscillator principle;when magnet pas over power coil, this will oscillate in conjunction with red switch,fragmenting the impulse in many little impulses  returning  huge amount of radiant energy ;If you do it just right ,you will have all energy you need to charge back the power source ,the battery,so the rest of the coils will producing energy for what you want...
http://www.google.ro/url?sa=t&source=web&cd=1&sqi=2&ved=0CBoQFjAA&url=http%3A%2F%2Fwww.fluxite.com%2FWorkingRadiantEnergy.pdf&rct=j&q=A%20Working%20Radiant%20Free%20Energy%20System&ei=FZlaTvxX0_rhBI317awF&usg=AFQjCNE1CA7ZGC6lnh_l2v9VGvqZDxSeag&sig2=kxYJOTRV9czCk6ixVGg6hg&cad=rja
SkyWatcher123
Hi folks, Hi sinergicus, thanks for posting that pdf, i have seen that invention before, though never built any test model.
I happen to have a muller type setup im finishing now that i could use to test this principle.
I will modify another rotor magnet shaft i have and make the diameter larger with a stack of neo magnets on each end that will pass my 5 coil/cores, this way, like mullers setup, one magnet will be in front of core/coil while other rotor magnet stack that is 180 degrees opposite on rotor will be attracting towards another coil/core.
When I get to the point of testing, I will let folks know how it works.
peace love light
tyson
