Muller Dynamo
0 Members and 18 Guests are viewing this topic.
konehead
Hi all
Here is a very interesting farily long 1/2hr video showing "diode plug" circuit in a transvertor (here he is using using as a nice HF panasonic microwave over transfomer in this one and you get the core of it to resonate, "stochastic resonance" its called, and then you have excess power (OU) on the secondary side of the transformer, in a nutshell here, but then how do you EXTRACT it without killing it into resistance??
He shows here how to do it - VERY similar to the diode plug circuit I put up two days ago that can be used for genrnator coils like in a RomeorUK machine.. - 4 diodes, 4 swtiches, two caps, and one genrator coil in what I showed....because in the RomeroUK rep machines, there are permanent magnets indcuing the coils, I dont thing youhave to worry about the "AC slip" making things go un-synchonized like the video shows at end of it...
video:
http://www.youtube.com/watch?v=UHyPniI1bS0
my similar diode plug circuit to use for genrator coils again:
konehead
Hi all
hers a one minute long video you should all see to confirm the importance of those magnets behind the cores - speed of DC motor goes up huge, and draw goes down, with magnet on back of transformer runnign small DC motor...reverse polarity of magnet and draw increaes horrible and speed goes way down.
http://www.youtube.com/user/dreamyear#p/u/26/2kosQIrDCWM
nvisser
T-1000
Quote from: konehead on August 30, 2011, 02:08:40 PM
Hi all
Hi,
In case of magnet near transformer - one polarity side increases inductance (and active resistance) with relation of current polarity and flipped side polarity decreases it so you need more current to keep it up.
You can easily measure inductance when attaching multimeter instead of powering up circuit and see how it's affected.
Cheers!
i_ron
Quote from: konehead on August 30, 2011, 01:46:42 PM
Hi all
snip
Doug, I believe your sine wave depiction is incorrectly drawn
Here is a scope shot of a single magnet passing a single coil...
Your plug concept is valid, just there should be zero induction at TDC.
It is the DIRECTION of MOTION that determines the polarity. As the magnet approaches it generates one half of the sine... and as it leaves it generates the opposite.
Cheers,
Ron
First pic...correct
Second pic...wrong
