Muller Dynamo
garrypm
Hi Chalam,
I think you've created a magnacoster
Garry
chalamadad
Quote from: Magluvin on October 07, 2011, 01:05:01 AM
One more thing.
Can you try to see if the driver coil sings if you just hold the rotor in the right position? Be interesting to see if it sings continuously and see what haps on thos other coils without the rotor spinning..  ;] Gotluc had a setup that oscillated, no rotor.
Mags
Yes Mags, it does oscillate continuously. I had this tested. The rotor magnet needs to be over the coil and it keeps going.
The output is definitely higher when the coil sings. You can see that in the video, when I was trying to hook up the load the voltage went down, but that is because the hall sensor has moved a millimeter and the coild stopped singing. Then I position it back to the sweet spot and voltage goes up again (est. double).
Cap size is 47K, 40V.
This particular driver circuit is exactly what Romeros contraption was using.
Kone, about your questions:
The coil where the probes are connected to first is completely disconnected from everything except the scope. The one next to it is a generator/driver coil but I can have it as generator only as well. It also receives the spikes. Then I have the singing driver coil and another coil behind it as a generator. These three go through bridges and into cap.
Again, voltage is higher when the coil sings.
The rpm does change when the coils sings. It is getting slower but can be tuned so it keeps going and still keeps singing.
Also RPM is as slow as you see it. Very slow.
Input amps is fluctuating but it does that anyway and the measuring frequency is bad so that needs further testing.
Each coil has its own FWBR.
The sound you are hearing is the oscillation of the coil. When the rotor magnet is ontop of the coil it keeps singing continuously and the scope shows continuous oscillations.
Oh, and this time I got 2 dislikes on youtube too. That's definitely showing that I am on to something.  :D
Chal
mariuscivic
Hi chalamadad!
I remember i had the same singing driving coils in one of my previous setup,but for now i can't replicate it. I've changed my setup so many times that i don't remenber how i did it.
Waiting for some new details.
Good luck!
For now i'm stuck with my new 15 mags rotor witch didn't gave me the results that i was expecting
Dave45
If you connected the rotor ends like Ed Leedskalnin's pmh you would only have to charge the coils one time, as long as the magnetic field was connected the E field would replenish itself, energy for free, free E field.
Saturn's E field.
Dave45
With the rotor running in the E field the magnets become supercharged it should blast any pickup coil around the rotor.
Dave
