Muller Dynamo
0 Members and 38 Guests are viewing this topic.
Collapsingfield
Just for fun: three similar magnets + two ferrite rods
hartiberlin
Many thanks for the flux animation.
I wonder what would happen, if your used
a iron backplate from the upper top stator
magnet to the lower stator magnet to close the
magnetic fields.
Would indeed concentrate much more flux into the airgap
where the rotor magnet goes through.
Also pretty interesting to see, that in the center of the
coil´s ferrite rods there are opposing fields, when the
Interesting would be to set it up that the
ferrite rod would then have a reversed flux field.
This would need the stator magnets to be further away from
the ferrite rod cores.
Regards, Stefan.
neptune
@Collapsing field .That was a very interesting and relevant simulation . Now can you [or anyone] answer this question . What would ne the effect if the ferrite core was lengthened by [a] 25% and 100% . the reason I ask is that i am trying to find out if the length of the core is critical . The main reason is that some people are anxious to work with materials they have easily available .
bolt
SNIP Don Smith
Magnetic permeability is the counterpart of negative
resistance. Resonating with negative magnetic resistance, it pumps energy from the Earth's ambient
background. Magnetic permeability is the ratio of flux density (Earth's B field) to the magnetizing force
(H) in oersteds.
Magnetostrictive materials are piezoelectric in character, and have a very high resistance to electrical
current flow. Examples are:
1. Permealloy Negative Magnetic Permeability
> 80,000
2. Sendust Negative Magnetic Permeability
30,000 -120,000
3. Metglas Negative Magnetic Permeability
> 200,000
4. Iron with ( 34% ) Cobalt Magnetic Permeability 13,000
5. New Technology Magnetic Permeability
> 1,000,000
Look for high Permeability cores Metglass and above. See scope shot taken off coils shows not AC but pulsed Alternating DC with resting time.  This rest period is the ZERO POINT its where the core undergoes negative entropy and put energy into the system. Be interesting to see current at this point i would expect to see current at max when the voltage is at zero point thus for a moment the VSWR is max for a standing wave condition.
neptune
@all. I previously asked Romero if he had tried stationary magnets on the coils down below [lower deck] He is likely under too much pressure to answer me . HE MUST HAVE TRIED THIS , AS OTHERWISE , THE LOWER COILS COULD BE DOING LITTLE EXCEPT WASTE ENERGY . Has he discussed this with anyone else please ?
