Muller Dynamo
0 Members and 31 Guests are viewing this topic.
mariuscivic
Hi guys
Been playing with coil shorthing technik and lenz is working 100%. Got 6 coils that are shorting at both peaks and the output is not so great.  The 22000uF cap goes to 20V in around 30 seconds. This cap has a lot of juice but still...there is lenz and the input power is bigger.
Anyway...i just looove spining disks. In this new vid we can see how can we gain more than 1000rpm with a small cap
http://www.youtube.com/watch?v=sXJw3vOaA80&list=UU9tULTcP96I5ZdBmoH0gL_w&index=1&feature=plcp
konehead
Hi Mariu
In the new video, I  will bet you are giving the backemf/recoil of the motor/drive coil "somewhere to go", besides backing itself up on the current pulsed into the motor coil, so it makes for that increased RPM...
Better to put it into DC cap, with a "Steering diode" off the source lead of the mosfet, since then you can pulse that cap out into a DC load (like a battery), to gain additional "normally wasted" power besides also helping the motor coil run better and faster like the AC does....
sothe AC cap makes it run better but i dont know what you can do with it when it fills up...T
That 220000uf cap is WAY too big...Mr Lenz's ghost is enjoying watching you suffer....
its like having a resistance across a small up cap while you try and fill it up and it doesnt work since the coil shorting event MUST  see no resistancw, or very very small resistance,  And the sistanc of cap that size is huge....he effect is snuffed-out like what is happening now when you try and fill a 22000uf cap......I know Romero could fill up cap like that, but he was doing a whole other thing! (not sure what still but it for sure wasnt coil shorting at peaks - if so, he would of told us the 8 days he was posting after it looped before he got threatened...his circuit have nothing to do with it that is for sure)
For the particular coil you are shorting, you need to find a good size cap that fills up fast, doesnt lug rotor and then after finding that out,  go higher and higher in uf value until you see the cap is too big and lugging and/or slow filling time starts to happen....then that is the limits of cap size you will have to work with...
Additional step you need to move up to, is to dump cap to a load while cap is disconnected from the coils (two stage circuit)
that big cap is like having a load on the shorting circuit, on the DC side of the FWBR, all the time, and its not going to work like that....tyr small uf caps on each of yoru 6 coils being shoted, then run them all in paralell to output, after they fill u[, when you get to stage of "two stage output circuit" if you want lots of power happening....
FreeEnergyInfo
Quote from: mariuscivic on January 19, 2012, 07:52:46 PM
Hi guys
plyz posted  shematic circuit ...
thanks video...
mariuscivic
Quote from: FreeEnergyInfo on January 20, 2012, 09:55:20 AM
thanks video...
is the romero driving circuit without the 1n4007.Then you have to find the right capacitor to put in paralel with the coil.
Today i have replaced the transistor with two mosfets. The bemf is so high that i can smell the ozone from the coil's wires and i'm not joking. The caps are charging like never before with the rising rpm and less curent consumed.
FreeEnergyInfo
OK ,
SORY MY ENGLIS == GOGLE TRANSLIATE ....
PLYZ POSTET SHEMATIC CONECTED ...
R=?.....
AČIU LABAI JUMS , BET AŠ ANGLIŠKAI NESUPRANTU,GAL JUS GALĖTUMĖTE IDĖTI BRĖŽINI BANDYMO ....
ANTANAS.
LITHUANIA
