Muller Dynamo
0 Members and 53 Guests are viewing this topic.
totoalas
Another variant of bridge rectifier by Jonny   from  JT a
The efficient rectifier circuit spins the motor on less input to the slayer circuit than a bridge rectifier made from 4148 diodes but the single transistor rectifier will spin the motor on the least input to the slayer exciter.
If you try the efficient rectifier circuit.Make sure you use two 4148 diodes and one 5408 diodes.I have uploaded the circuit diagrams to my previous post for easier reference.Cheers.Jonny
http://img135.imageshack.us/i/efficientrectifiercircu.jpg/
nul-points
Quote from: lanenal on May 10, 2011, 04:32:04 AM
I love what you have said! There is so much truth in it.
thanks lanenal
apologies for the rant, everyone
maybe we get back to our replication attempts now
Tudi
@nul-points thanks for showing everyones opinion. I tried to NOT divert the discussion in the wrong way. That is why i tried to write in bold my point. I'm trying to extract this new theory you are talking about, the ambiant energy that is absorbed. I could not find any post about speculations in what form does this ambiant energy comes from ( i know every second topic is about vacum and null point energy, but there is no vacum here to create null-point energy). Ofc as this theory is intended to be new, i do not expect that most speculation would even be close to the real reason. Things need to start at some point.
I could use your same speach for the sake of the development of the theoretical part. This even misunderstood theoretical part might help people improve their practical devices at some point.
neptune
@toranarod . Hi there . I believe you are in the process of coil winding . You could help us all here . Can you tell us exactly what wire you are using [ off the shelf multistrand or roll your own ] .The most vital thing you can do is to weigh an empty bobbin  and a wound bobbin and thus tell us the weight of wire per coil . This will be important for people buying wire .
         Cheaper neo`S in the UK . I bought 22 of 20mm x 10 mm mags for about £42 . magnetsuk.com
toranarod
I was asked this in an email today. I thought it was very interesting.
just an observation.
Notice how close this technology is to the Adams and the Bedini technology. They should be paying equal attention to the dynamics of their transistor. They might find out that another transistor might not work as well â€" if at all.      Consider that a focused and serious inventor can make his machines work through the sheer power of his mind â€" and not know it. He can make his setup work, but nobody else can. That guy in Canada, Hutchenson, and Hendershot are good examples. If They are not in the room the equipment operated by someone else just doesn’t work. This is a problem that comes up now and then â€" and something to keep in mind.
