Muller Dynamo
0 Members and 40 Guests are viewing this topic.
Scorch
You beat me to it.
I just watched the video.
See: http://www.youtube.com/watch?v=Zu4pzvkSkzo
I am encouraged to see another configuration besides sine wave peak alternator.
In this new configuration he is no longer using a sine wave peak commutator and relays.
I would like to learn more about the differences, the pros & cons, of sine wave peak versus toroid generator.
I do intend to get more assembly work done soon.
Quote from: marcx41 on June 01, 2013, 12:59:43 PM
Good morning Thestone and Scorch........Q3 is born. I am working on my replication of Q2, that take a lot of time, I am late .....step by step.....
Scorch
Just a quick follow-up.
I was not able to get the work done, this weekend, as I had intended.
But I have heard back from the manufacturer so no worries there.
They are simply doing their own thing and they are still in touch and offering to fix problems.
And, to me, this is really what counts. Just being able to communicate.
So I see no problems there. Just a few delays for various reasons.
SO all is good at this point and I still have a deep appreciation for what I have and what we are all trying to accomplish.
Just need to get off my lazy tail, worry less, and build more.  :)
That is all for now.
PS:
There is, apparently, a very fine line between constructive criticism and complaining. . .
Quote from: Scorch on May 25, 2013, 12:29:00 PM
.....  So, for the remainder of this holiday weekend, I give them the benefit of the doubt.
But, if it starts to become clear this company is NOT communicating, backing up their products, or correcting errors then, yes, I will take the position this is the case. . . .
T-1000
Quote from: Scorch on June 01, 2013, 01:54:18 PM
12:10 there is the bingo moment. Shorting of toroidal generator did not afected much pulse motor but when vacuum pump was attached its motor was running. The toroidal generator smells on what N. Tesla was doing... :) Someone need to pick this up and see if more energy can be generated than energy was needed to rotate magnet inside of ring. The most important bit there are coils arrangement to 90 degrees than you expect on conventional generator and plenty of iron to weaken Lenz force.
Scorch
Just a minor progress report of minor progress.
I managed to spend an hour wiring the alternator stators, and cutting threads, so these parts are all ready.
The company is still in communications and has promised to send more adjustment nuts, as well as additional magnet retainer shims, but I went ahead and finished cutting the nuts I have on hand.
It does appear that 3/4"-20 was the correct tap so that worked well and I was able to mount the alternator section for an initial mock-up.
But I can now see my rubber band solution (to replace missing shims) just isn't working as well as I had thought because I couldn't find rubber bands that are thin enough.
Now that the rotors have been assembled, for awhile, not only am I seeing a 'bulge' in some of the magnet cups; I am now seeing a slight gap, between the rotor halves, in some areas near the magnet cups.  So; I would really like for those replacement shims to arrive soon. . .
Another thing, I noticed, is that the plastic coil bolts are really close in the middle.
Wouldn't hurt for the manufacturer to go the next size, shorter, bolts.
Scorch
Just a side note-
Quanta Magnetics did send replacements for the missing shims, and adjustment nuts that weren't threaded all the way through, which have arrived today.
So all is good.  :)
And there is a new video that shows a very interesting effect.
Depending on where he moves the 'timing' of his switch, there appears to be a significant increase, or "Toroidal Power Amplification", in power output from the toroidal generator.
See:
http://www.youtube.com/watch?v=d3b3h2cEbHw
I sure would like to learn more about toroidal generators and these switching effects.
