Muller Dynamo
0 Members and 83 Guests are viewing this topic.
Scorch
No. The Q3 was not a bifiler configuration.
This will be part of the conversion; to rewind the original coils as bifiler.
This may not be very difficult. Provided he is using the same gauge wire; I should be able to simply unwind the coil then rewind it with the same wire doubled.
It will be half the length and turns with two conductors that still fill the spool without need to use any new wire.
Quote from: Magluvin on February 17, 2014, 08:13:02 PM
I saw that vid of the new model. Does yours have bifi coils?
Mags
crazycut06
I believe doug konzen uses this kind of bifi on his run coils, to pickup induced magnetic field from primary, then secondary coil goes to cap.
crazycut06
@ schorch,
Feel free to create another thread for your experiments, this may help others in the future if they want to replicate things, right now i'm interested on replicating the toroid gen. Of the T2, if you have time pls. Post your findings on this, i will be following, thanks...
Cc
e2matrix
Nice work Scorch - I check in here once in a while.   The T2 video - LOL - no drama there .... but that guy really is an incredible builder.   Just wish I had the $$ to buy one of his units to play with.   One thing came to mind in looking at your challenges with the toroid - do you think the (aluminum ?) bracket you added may effect the magnetic field with that?   That setup does look like a real challenge to get together properly.   BTW do you know what the big green toroid material is made from and the permeability of it?    Best of luck with your build.
Scorch
Yeah, no drama, at all.
I think I can hear his frustration as he tries to demonstrate that, yes, in fact; the battery IS charging. . .  :D
A charging battery simply is not a dramatic, action packed, scene for any video production.
No; I don't believe the aluminum brackets have any detrimental affect and these are the brackets that came with the kit and not something I added.
And here are the details for the core part #T650-52-
http://www.micrometals.com/pcparts/torcore7.html?zoom_highlight=T650-52
PS: Once again; it appears that PMM4GHYBRID is holding back.
If you review the video; you will notice that, again, he is not actually demonstrating ALL the potential charging outputs of the device.
At 21:40 into the video; he points out that he is not even using one of the outputs which may be used for additional charging.
Quote from: e2matrix on February 18, 2014, 03:06:36 PM
