Muller Dynamo
0 Members and 31 Guests are viewing this topic.
PiCéd
This has nothing to do with the topic but it is interesting.
Well, I done some tests and it apear that a DC motor and a capacitance acts like two batteries in parallel, in fact the more you turn the motor to charging sens the more easier you can charge the cap.
For exemple, I have try with a monopolare chemical capacitance of 0,0047 farad, it apear that the turn of the motor is as easy (maybe more) than if the motor turn with no short_circuit and the cap is perfectly charged, aproximately to the same voltage than the rotation of the motor (1.5 or 1.9 volt). It work well if you remove faster the cap befor the motor begin to move more slowely or if you have a diode blocking the charge returning to the motor.
I don't think we can do that with an alternator.
With my other tests, first I just connect a battery of 1.5 volt to each side of my motor, it turn on one sens, then if you replace the battery by a multimeter on each side of the motor and turn to the same sens like the prevous test (with the battery) with you hand, you can see that your motor produce the same charge in the same side than the battery, the motor must only be DC.
It is two tests realy easy to done.
crazycut06
He's holding back the potential of the toroid, like he said in the video, he removed the coil shorting circuit as not to shock the user, maybe for safety reasons, he doesn't want his machine to be a shocker!  :o Haha.. But for advance user it will be favorable, in battery charging, imagine a more powerful bedini charger many times more bemf! As an intro for his machine not bad, no drama at all  ;D ...
Magluvin
Im posting this here because some parts are related, such as speed up under load.
It was presented at Peswiki. A few guy from the Ukraine worked this out, and seems good. Very interesting demo. ;)
http://www.youtube.com/watch?v=3c0X6nSsj7w
I had tried something similar with an air core, as a motor, not a gen, and had some weird results.
Mags
crazycut06
Quote from: Magluvin on March 03, 2014, 09:19:07 PM
Mags
Well i think this is not new, i've  seen an old video before with this kind of setup, only his core are shaped C but with same effect, also others experimenting with ed leedskalnin perpetual motion holder, U core same effect also, speed under load, might be related with the T2 gen. Worth experimenting with.
gyulasun
Hi Folks,
Recently a new member Miroslav13 started a new thread on that setup at energetic forum:
http://www.energeticforum.com/energetic-science-ministries/16629-motor-generator.html#post251601
He is willing to answer any technical questions...
Gyula
