Muller Dynamo
captainfletcher
Hello
I would like to submit my problem:
I began to replicate a wheel as shown PMMG4HYBRID .
Therefore the wheel 8 is in place with magnets 2 cm in diameter, the wheel diameter is 25 cm .
At first I placed a single coil , it weighs 450 grams with 0.5 mm wire and I wanted to do a test.
By turning the wheel with a screwdriver at about 800 revolutions per minute , there is 4.5 volts vacuum across the coil.
There is no core in the coil to avoid cogging .
If I put two coils in series there should be 9 volts, this is not enough. What should I do?
For the purchase of copper wire is expensive especially for a possible failure.
What is the architecture of this system is the best for a good performance?
The answer is important because of PMMG4HYBRID my future project will be to build a machine of 10 Kilowatts for home .
Our friend had a lot of thinking on all these systems and it would be a shame to reinvent the wheel is the case to say it.
PMMG4HYBRID thank you for helping us , all comments are welcome.
Captainfletcher .
Sorry for my English.
Scorch
It's my understanding his system is still in development and the current, "T2", model is still being improved.
My impression is that these systems will be more efficient operating at high voltage but he may be a little hesitant to release a high voltage version to the public as a mere experimental kit.
There are certainly safety issues to take into consideration with these things before just selling them to any Joe on the street.
I would like to convert my Q3 to a T2 so I am just waiting to see what the next generation of the T2 might evolve into.
So my Q3 project is on standby while waiting for these future developments and other possibilities such as the QEG.
http://hopegirl2012.wordpress.com/2014/03/25/qeg-open-sourced/
http://pesn.com/2014/03/26/9602463_Quantum-Energy-Generator_QEG_Open-Sourced/
Kindest regards;
Quote from: captainfletcher on May 04, 2014, 04:19:34 AM
Hello
Captainfletcher .
captainfletcher
Hello,
Thank you very much for your response Scorch.
I continue my investigations generators Coreless and browsing the web, I came across the bike engines and wind turbine engines.
Some motors or generators are much like generators or PMMG4HYBRID Muller.
There is no core so no cogging and performance are very good from the PDF.
The architecture is quite different, there is a coil but two magnets on each side of the coil.
So the mechanical assembly is different. I am researching to find a small wind engine cheap to change.
axial flow type coreless motor
What do you think?
What is amazing is the power delivery at low revs.
There are also less copper so the generator will be cheaper too.
All comments are welcome.
Scorch
I think there are many designs out there and I have no idea which is best and probably depends on application.
Are you aware there is a huge, 2,600 page, book called "Practical Guide To Free Energy Systems"?
This book is updated pretty regularly, will probably keep you busy for quite some time, and is available for viewing or download here-
www.free-energy-info.com
It's my belief there is something like 5,000 known patents, for alternative energy devices and systems, that are not available for public scrutiny under guise of 'national security'.
Any system that threatens 'our oil interests' (including profit margins) is a threat to national security which will be defended to the death and many have either died, been discredited, or financially assassinated for attempting to bring such systems to the public.
As long as people silently consent and not object to such laws, defending profit margins of energy companies, they will remain. . .
Quote from: captainfletcher on May 05, 2014, 05:07:05 AM
Hello,
What do you think?
fabioharry
Good morning!
I'm new to the forum, but I've been watching this and other threads a while ago.
I'm building something like the Q3 Quanta Magnet, but I'm with some doubts about the basic operation of the generator.
1 - How is the push to spin the rotor?
As I understand it one of the coils is transformed into an electromagnet, correct?
2 - The same coil that is shifted toward the electromagnet also captures energy?
3 - If one of the coils is shifted toward the electromagnet it will be different from the others, but the generator to work properly it is necessary that all coils are equal, this thought is correct?
4 - Does anyone have a tip for building this magnet / coil?
I'm racking my brains to unravel these issues.
Sorry my English, because I do not write very well.
Thank you all.
