Muller Dynamo
fabioharry
Quote from: captainfletcher on May 08, 2014, 03:11:06 PM
Boa dia Fabio,
Response to Question 1:
Yes 2 coils become electromagnets to approach the magnet.
Response to question 2:
When powering the 2 coils store energy .
Provided that the coil has a capacitor across . ( LC circuit)
At top dead center , the power is off , so the LC circuit will restore energy and repel the magnet.
It appears that the energy released is greater than the energy supplied to the attraction of the magnet.
Otherwise the system can not function .
It also requires that the LC resonance is related to the speed of movement of the magnet in front of the reels.
Experimenters have neglected this very important condition and have experienced failure.
Moreover notice that the machines to stabilize 700 to 800 revolutions per minute .
I do not understand the question 3
Response to Question 4:
I myself work on this project at this time.
I crafted 2 wheels 25 cm in diameter with 8 magnets each. ( Magnet 2 cm by 1 cm. )
Today I made a coil which shall be fixed between the two wheels.
If I have time tomorrow , I'll put it all together and make voltage measurements on the coil.
I will turn the wheels with an electric screwdriver .
Até logo. ( Vôce es de que citade ?  ja fui no Brazil mas ja qualquer annos , gosto bem, desculpe me para as faltas. -)
@ Scorch
I do not know why, sometimes I thought it was you ... PMMG4HYBRID
Do you know if it works on this forum?
Best regard.
Lets get this straight, the 9v battery powers the relay, the relay in turn feeds a coil, the coil in turn behaves as an electromagnet that causes the rotor to rotate.
Summary: 9v battery> Relay> coil> spinning rotor
By Lenz's law, when approaching a magnet in a coil causes the coil to be equal to the polarity of the magnet polarity.
The coil which is used to rotate the rotor core has?
In a coreless coil the magnetic fields are not aligned, but when there is an iron core the magnetic fields are aligned.
It is possible to rotate the rotor with a coreless coil?
The system of Q3 or QC equals the RomeroUK?
Thanks Scorch and captainfletcher the answer.
Captainfletcher, cool, live in Florianopolis, State of Santa Catarina.
Scorch
Q3 is not the same as the RomeroUK design which has odd number of stator coils to rotor magnets, such as 8 magnets for 9 coil pairs, and does have ferrite coil cores as well as 'bias" magnets on coil cores.
The Q3 is equal number of stator coils to rotor magnets at 6 magnets for 6 coil pairs and coils do not have cores or bias magnets.
And, yes, very easy to rotate the Q3 rotor with its coreless design.
The extra 'pickup' coil was merely an extra generator coil to keep 9v battery charged to power relay switching.
In my opinion; the RomeroUK design is very unique and does have potential to operate as a resonate system and should be pursued further.
In fact Zero Fossil Fuel appeared to discover some very interesting test results from the RomeroUK design including achieving a resonance and voltage spike from his system.
Then . . . he has done nothing more since this apparent discovery and "unlocking the secrets" and I have no idea why.
I do find it very difficult to believe his explanation of: "life happened" from a man allegedly dedicated to exploring these alternative energy systems and who had an "extraordinary" effect from the working system on his bench.
To Quote from his video: "Something quite extraordinary happened . . . it resonated and the voltage spiked . . . once this baby hits 88 mph; you're going to see some serious stuff."
This was three years ago and he has done absolutely nothing more with this system since then and I have no idea why.
https://www.youtube.com/watch?v=yoXZHdiMCKE
So, at this point, I wish somebody else with more knowledge, than me, of inductance, reactance, capacitance and resonance would continue this work and build the resonant system that Zero apparently built but, then, disassembled it and sold the component parts. . .
Why did Zero build a system he claimed was producing an extraordinary effect then simply discard it and spend 3 more years building many other things that have not produced an extraordinary effect that he already had in a working model on his bench?
Quote from: fabioharry on May 10, 2014, 11:51:08 AM
fabioharry
Quote from: Scorch on May 10, 2014, 01:01:15 PM
This system has great potential!
You can not intender because he is giving up on your system.
I have some magnets and coils will ride some for testing, I intend to build a rotor diameter of 40 cm.
I'll try to build a generator in the style of Q3.
When I have put on the new forum.
Thanks for the information!
captainfletcher
Hello Fabio and Scorch,
You can see my post and photos on this forum in French
http://www.conspirovniscience.com/forum/index.php?showtopic=1616&st=0&#entry49034
This week-end the  Timing's disc is finished.
I have to fixe the coil between the rotor's flasques ( I can not translate in english  )
I hope  mesure, tune  the machine this week. ( capacity on coil )
Asap.
romerouk
@Scroch
Do you think it is possible to be controlled 'remotely' on what to do or what not to do, most of the time without even realizing?
Do you think that you can be disturbed, distracted or even killed without being in direct contact with someone looking to keep you silent?
If you play nice within the limits you might still have a chance if not you will start feeling bad, ill and blame some health condition you might have, in fact all you are under a strict control.
This is not fiction.
Regards,
Romero
