Muller Dynamo
0 Members and 23 Guests are viewing this topic.
Magluvin
Quote from: khabe on May 10, 2011, 11:56:59 AM
No like rain cats and dogs there is coming differnent OUs   :o
Look at Hoppy´s TPU Replication  http://www.overunity.com/index.php?topic=10710.msg285458#new   :o
But OK, when Romero´s - Muller dynamo really works, then why to use rotor with magnets at all  ???
Just take two ferros core coils, set it up exact like one Romero´s unit with two coils and instead of moving magnet just use third ferros coil between these two coils - but this third is pulse driven,
NS->COIL->pulse-driven-coil->COIL->SN
Yes, this is very similar to well known units from other threads, but you must have all the same air gaps like Romero and top and bottom magnets - you must replicate all this like opened magnetic circuit, like Romero did.
Benefit of this experiment is you do not need so much different part. At that you will get solid state OU (if at all)
If it works - then you can be sure that Romero´s device works as well,
If it does not work - then ...  >:(  ... oh dear  8)
Why I do not try myself?
Because I have tried looooong time ago - no way  ;)
I just looked Romero´s video and wonder why he is holding hes machine by hand, why not just by string or something like that?
What is behind holding hand, we do not see. Why there are so much wires? Like always - lot of wires, shabby imaging, failure cameraman ...
Was no time to make order, to short all wires for correct length? .... Come on, guys  ;)
He did what he did --- few days like shooting star, but now is coming a thinking time, to think about results and ... about reputation  :(
But anyway I wish good success,
cheers,
herbert
cheer
Actually, there is quite a difference between your solid state version vs Romeros.
There are changing angles involved in Romeros setup, yours not, it is stationary.
Seems most dont get that the field lines need to pass through the windings to produce current, not just the core.
Think, how could a wire come in contact with the field if its all in the core. It cant. The wire does not have feelers around it to come in contact with the field in the core. Same as a transformer. An E core transformer has lines of force expanding from the center core and cut the other windings on the way to the outer part of the core.
Read he pdf attached.
I have seen a solid state version that seems it may imitate Romeros function. It had 2 driver coils off center to the pickup coil. I believe the driver coils alternated the fields produced on each side of the pickup.
This will enable the field lines to pass through the windings much better than an inline driver.
Mags
lasersaber
@ e2matrix
I will try arcylic as well if this first rotor fails to work.  I do not give up easly on anything.
chrisC
Quote from: lasersaber on May 10, 2011, 12:55:28 PM
@ e2matrix
@lasersaber
Tab Plastics sell several 5" to 14" ready made circular plates that can be used for stators and rotors for this replication. Check them out. It's less than $10.
Oh, here's the link:
http://www.tapplastics.com/shop/product.php?pid=140&
cheers
chrisC
Magluvin
Quote from: e2matrix on May 10, 2011, 12:52:21 PM
Best to just ignore people like that at this point.  At least don't waste a lot of time on trying to prove anything to them.  A long time ago I came to the conclusion there are two types of people in this world: the believers and the sceptics.  It's almost impossible to convince a sceptic to be a believer.  So when I know I have something good to share I try to find out first which type I'm talking to and won't waste time on skeptics.  With as many of the top builders that I've seen in this thread I'm sure there will be successful replications within a month or so.  So don't sweat the skeptics and trolls.  Anyone with a clue about human nature can see you are an honest builder with only good intentions and real OU.
I agree.  Dont worry about nay sayers. You know what you have. Their bickering will end when replications come about. Just concentrate on that. Thats all that matters.
Even if there are 50 good replications, the bad words will still come. So what. lol  Let them stick with $5 a gallon gas.  At $10, they will be on their knees next to their Ford Excursions, in tears.  ;]
Your doing fine Romero.  Its hard to ignore. But it is the best policy.
Mags
e2matrix
Romero if you are still around just one question on what you used for spools or bobbins to wind your coils.  Were they sewing type bobbins?  I see some on ebay with these sizes: SIZE:    3/4 inches (20.5 mm) wide & 7/16 inches (11.5 mm) thick and  1/4 inches (6.4 mm) hole diameter.  Sound close?
