Muller Dynamo
0 Members and 212 Guests are viewing this topic.
hartiberlin
I just see,
that in the
the start voltage position from the battery is still wrong.
In the video it was on the other side of the DC2DC converter...
but that is not so important, as the unit starts also itsself
when turning without any battery, RomeroUk said.
And the analog input ampmeter is also still missing,
but this is only a minor detail.
It is directly behind the Dc2DC converter output,
so it will also register the current going through the 20 Watts bulb.
Regards, Stefan.
eisnad karm
The reality is thst no compsny would be offering millions of dollars on an open source project as their only protection is IP. Given his full dislosure and details it would be impossible to get one through now without being challenged..and what exactly is the IP. Many other experimentors could lay claims to the different aspects of these deigns.
However removoing all trace of everything was proberbly a request if he did have a real offer..too late many have backed it up.
You should contact the so called companies Stefan to confirm that...i would be very suprised if it was a reputable one as there are many claiming to have millions and they do not.
email me privately if you like or call me and i will tell you if they would be authentic. If not do your own homework.
Is it real or not, I do not know but given the information availabe you would expect one replicator to have success at least. Then what happens then? The replicator might discover further improvements. This is a real pandoras box.
Mark
infringer
ROMERO ROMERO ROMERO!!!! BUDDY ARE YOU SERIOUS YOU HAVE PERPETRATED A FRAUD?
People let this be a big lesson if you ever achieve overunity make dam sure you have every detail down to the type of epoxy you used and how much and every measurement!
And if you can afford the time even share a link on where you purchased every part from.
It will save you much headache then you drop this in there lap it will be purchased and built lickity split.
There will be no questions just replication make it with everything purchase ready! So its just a matter of slapping it together if you do not do this it will give people time to stop affording you the short window of belief that you have!
I am a little at fault for the whole deal and I do apologize to all of you out there who have stuff on the way... But I knew the questions would start pouring in so I tried to get them out of the way right away to prove there are no batteries or trickery...
Aside from all of this if he did pop open the DC converter it would likely run cooler and have a slightly better efficiency so why he was so against this is beyond me????
And as far as the cap goes if you visit www.badcaps.net you will find out that even caps were being pirated back in the days people were using cheap caps and putting them inside caps with a good name and the wrong specifications this is how some of the orientals got rid of all there bad capacitor stock.
Would you not want to verify this is not the case with the capacitor you are using????
Finally you just built an overunity device would you not want to go out of your way to prove that it is in fact overunity???
If he was really christian I would say that he is lacking of some of the morals of a christian the lord was very forgiving according to the bible and he sacrificed so much even his life so he could die for the sins of man and yet this guy cannot forgive a simple question or sacrifice ten more minutes to make a video with the capacitor being torn apart after the running of the device I do not understand?
Anyhow he can leave and give up that is his choice just remember when it comes time for judgement and you are waiting at the pearly gates and you did not make just a little more sacrifice to possibly save the billions of people headed for starvation and homelessness around the globe if your name is not on the list you will know why. There is a reason you were given this gift while the millions of others may have missed it... At the end it is all about what you have done to make the world a better more fair and equal place it aint about how many cars you had or whatever you don't take them with you and that is what a true christian believes no matter what!
Finally as far as the guy being rich if we were able to replicate this thing he would have received many more millions in donations then he ever would have gotten from some oil company or the DOE plus he would also go on to live for ever even after he was dead and gone.
Just some things I believe he should really consider if it is real cause if I were him I know it would be on my mind.
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
David70
Looking at the schematic above I see 2 1n4007 recovery diodes.When the switch is off  is possible to have the LED lit by them while the rotor still turns.Is the big capacitor connected before or after the switch?
SkyWatcher123
Hi folks, As the old saying goes, 'you can't burn the candle at both ends' and expect to be free, money is all illusion, as is much else.
Here is what I have so far, using 5/16" diameter steel bolts, for now, though ferrite cores can be easily be attached to this setup later.
The reed switch is only temporary, to see how the motor function works and I'm waiting for glue to dry on other 5 coils, polyurethane glue takes awhile to dry.
peace love light
tyson
