Muller Dynamo
0 Members and 115 Guests are viewing this topic.
dole
Hi,
What a story!!
Eight days and nights. Little bit to short but I think we all really enjoy it, so do I.
Actually the lie or the truth, It does not matter, It myth be that just belief is enough.
I post this link somewhere before and apologize if you all ready read this,
another short story and I think it is completely the truth.
http://img1.liveinternet.ru/images/attach/b/2/3599/3599086_richard_bach__jonathan_livingston_seagull.pdf
So I hope you may like it and then back to work and wind some coils.
d.
abdlquadri
Quote from: khabe on May 10, 2011, 07:32:41 PM
Yeah, very grievous,  brings to tears ... but why these rich millionaires want to give big money to Romero but never gave any cent to Muller and Bedini   ???
cheers,
khabe
I see you are senior member. You should check up on bedini's history. He stopped developing devices that produce energy but only battery chargers - he was wise. Bedini already had a selfrunner since the 80's
abdlquadri
Quote from: infringer on May 10, 2011, 08:09:04 PM
ROMERO ROMERO ROMERO!!!! BUDDY ARE YOU SERIOUS YOU HAVE PERPETRATED A FRAUD?
People let this be a big lesson if you ever achieve overunity make dam sure you have every detail down to the type of epoxy you used and how much and every measurement!
And if you can afford the time even share a link on where you purchased every part from.
It will save you much headache then you drop this in there lap it will be purchased and built lickity split.
There will be no questions just replication make it with everything purchase ready! So its just a matter of slapping it together if you do not do this it will give people time to stop affording you the short window of belief that you have!
I am a little at fault for the whole deal and I do apologize to all of you out there who have stuff on the way... But I knew the questions would start pouring in so I tried to get them out of the way right away to prove there are no batteries or trickery...
Aside from all of this if he did pop open the DC converter it would likely run cooler and have a slightly better efficiency so why he was so against this is beyond me????
And as far as the cap goes if you visit www.badcaps.net you will find out that even caps were being pirated back in the days people were using cheap caps and putting them inside caps with a good name and the wrong specifications this is how some of the orientals got rid of all there bad capacitor stock.
Would you not want to verify this is not the case with the capacitor you are using????
Finally you just built an overunity device would you not want to go out of your way to prove that it is in fact overunity???
If he was really christian I would say that he is lacking of some of the morals of a christian the lord was very forgiving according to the bible and he sacrificed so much even his life so he could die for the sins of man and yet this guy cannot forgive a simple question or sacrifice ten more minutes to make a video with the capacitor being torn apart after the running of the device I do not understand?
Anyhow he can leave and give up that is his choice just remember when it comes time for judgement and you are waiting at the pearly gates and you did not make just a little more sacrifice to possibly save the billions of people headed for starvation and homelessness around the globe if your name is not on the list you will know why. There is a reason you were given this gift while the millions of others may have missed it... At the end it is all about what you have done to make the world a better more fair and equal place it aint about how many cars you had or whatever you don't take them with you and that is what a true christian believes no matter what!
Finally as far as the guy being rich if we were able to replicate this thing he would have received many more millions in donations then he ever would have gotten from some oil company or the DOE plus he would also go on to live for ever even after he was dead and gone.
Just some things I believe he should really consider if it is real cause if I were him I know it would be on my mind.
If it was fraud all he needed to say was I am sorry I made a mistake in connection or reading(anybody can make mistake) NOT take down his youtube account; take down his forum he has being building for years and tell us the world would remain the same.
bolt
Quote from: SkyWatcher123 on May 10, 2011, 08:20:11 PM
Hi folks, As the old saying goes, 'you can't burn the candle at both ends' and expect to be free, money is all illusion, as is much else.
Here is what I have so far, using 5/16" diameter steel bolts, for now, though ferrite cores can be easily be attached to this setup later.
The reed switch is only temporary, to see how the motor function works and I'm waiting for glue to dry on other 5 coils, polyurethane glue takes awhile to dry.
peace love light
tyson
Key to making this work is absolute essential to use ferrite cores as minimum standard. BUT its much better to use metglas or other extreme high permeability cores because this is the OU transform component. Expect to spend as much if not more on the cores as the neo magnets as they work in harmony.
Next is minimise all losses. bearings, build quality etc must be precision made. Unless you have several hundred dollars to spend on doing this properly then you are wasting your time and money.
Many people still doubt this device. Clearly never done any homework to see Muller made dozens and dozens of OU self looping generators. He sold quite a few i imagine they are still powering someone's houses today. Many people went to see him and his generators before he died.
Liberty
Quote from: eisnad karm on May 10, 2011, 08:06:19 PM
The reality is thst no compsny would be offering millions of dollars on an open source project as their only protection is IP. Given his full dislosure and details it would be impossible to get one through now without being challenged..and what exactly is the IP. Many other experimentors could lay claims to the different aspects of these deigns.
However removoing all trace of everything was proberbly a request if he did have a real offer..too late many have backed it up.
You should contact the so called companies Stefan to confirm that...i would be very suprised if it was a reputable one as there are many claiming to have millions and they do not.
email me privately if you like or call me and i will tell you if they would be authentic. If not do your own homework.
Is it real or not, I do not know but given the information availabe you would expect one replicator to have success at least. Then what happens then? The replicator might discover further improvements. This is a real pandoras box.
Mark
Hi Mark,
If you get time, check out the first movie.  The device starts out at v=12.61 and then firms up at 12.57 volts with current at about .94 amp.  When the light is turned on at time 2:53 into the movie, the voltage drops to 12.29 volts (barely seen in the side of the screen) and the amp meter drops also to .92A.  Then just after the light is turned off, at time 2:58, the volt meter jumps up and reads 12.48 volts and the amp meter reads .93A.  It appears that the light is running right off the battery but the current is not being read through the digital meter.  It has been fun to watch though.
Liberty
Liberty
