Muller Dynamo
hartiberlin
Quote from: Liberty on May 10, 2011, 09:04:07 PM
Hi Mark,
If you get time, check out the first movie.  The device starts out at v=12.61 and then firms up at 12.57 volts with current at about .94 amp.  When the light is turned on at time 2:53 into the movie, the voltage drops to 12.29 volts (barely seen in the side of the screen) and the amp meter drops also to .92A.  Then just after the light is turned off, at time 2:58, the volt meter jumps up and reads 12.48 volts and the amp meter reads .93A.  It appears that the light is running right off the battery but the current is not being read through the digital meter.  It has been fun to watch though.
Liberty
No,
if you look carefully you see, that the cables come from the rectifiers and not from the battery.
so the lamp is powered by the generator.
ZeroFossilFuel
QuoteAside from all of this if he did pop open the DC converter it would likely run cooler and have a slightly better efficiency so why he was so against this is beyond me????
Sorry folks but if he did take apart the "DC converter", all you'd see is the 9v battery that made his pulse motor go.
My public PGP key. Please help support my work. Donate by PayPal
hartiberlin
Quote from: ZeroFossilFuel on May 10, 2011, 09:26:46 PM
No,
cause you see exactly that the generator supplies the current,
Cause as he switches off you see exactly that the cap discharges into the
DC2DC converter and the LED lights still this long...
and then gets dimmer as the cap gets discharged...
If there would have been a battery inside the DC2DC converter,
it would have still run,
as the DC2DC converter was NOT switched off... !
Only the charging of the cap from the generator was switched off !
REDCAR1957
Oh man ya'll what about the genie? ???
look at and study what he has given you here  ::)
it feels like I have gone back 2000 years and looking  :'(
for a cross guys just have faith not doubt ;)
SkyWatcher123
Hi folks, Hi bolt, you said,
QuoteKey to making this work is absolute essential to use ferrite cores as minimum standard.
How can you know this for a fact, though you're probably correct.
I will be getting ferrite cores after I test this out first.
Ya no kidding zerofossilfuel, doubt is not part of the scientific process and doubt has never created anything.
peace love light
tyson
