Muller Dynamo
0 Members and 55 Guests are viewing this topic.
abdlquadri
Go on guys... we are almost there...
hartiberlin
Yes, now you are right, Fausto.
The left white cable from the black DC2DC converter cable is the positive voltage output of the DC2DC converter
and the right more silvery colored cable is the ground cable of the DC2DC converter output ( minus pole).
plengo
Quote from: hartiberlin on May 10, 2011, 11:23:15 PM
I am pretty convinced this is for real too. That was the only thing I could spot looking very closely to the videos that was strange (as I said before).
Everything on the video, the voltage fluctuations, the cables, the way the motor spins and current changes, the voltage variations of the DC and the motor reaction, the non-Lenz effect when the lamp is connected and the speed did not change.
If this was a fake is a dam good fake of tremendous details. Details of the level of one guy that should KNOW how it should behave in those conditions. Which is only possible for people that really experiment with this stuff.
I am glad I am doing the investment on the parts and I tell you they ARE NOT CHEAP at all and I will probably still buy more to make this correct.
I put my money where my mouth is!
Fausto.
e2matrix
Quote from: bolt on May 10, 2011, 09:00:55 PM
Key to making this work is absolute essential to use ferrite cores as minimum standard. BUT its much better to use metglas or other extreme high permeability cores because this is the OU transform component. Expect to spend as much if not more on the cores as the neo magnets as they work in harmony.
Next is minimise all losses. bearings, build quality etc must be precision made. Unless you have several hundred dollars to spend on doing this properly then you are wasting your time and money.
Many people still doubt this device. Clearly never done any homework to see Muller made dozens and dozens of OU self looping generators. He sold quite a few i imagine they are still powering someone's houses today. Many people went to see him and his generators before he died.
bolt,  any ideas where one can find some small metglas or similar rods?  I was looking for some but so far no luck.  Not sure I can afford but will consider it if I can find some.
lanenal
Quote from: plengo on May 10, 2011, 11:28:21 PM
Fausto.
Romero was going out of his way planning to get another video out to prove it's real -- despite of his complaints of such unproductive work and of his word not to do such video again (with many of us expressing our agreement and support on his decision) -- he is a nice guy. Then all in a sudden it is all interrupted, and he is seen no more here...What happened? I hope he is still alive...
