Muller Dynamo
0 Members and 92 Guests are viewing this topic.
David70
@khabe
are this supercapacitors 15volts? can you show a link?
that link before is for 2.5 volts
Diameter 1.3 inches (33 mm)
Length 2.44 inches (62 mm)
Tab width .25 inches (6.4 mm)
Tab height .23 inches (5.9 mm)
FreeEnergyInfo
INFO....
FUL INFO RomeroUK  HD VIDEO , FOTO  my syte ....
free dowload ,save,copy...
PEACE.....
http://freeenergylt.narod2.ru/muller_dynamo/
http://www.youtube.com/watch?v=T1lBhkZI7Ds
lasersaber
Here is what I have so far.  Now I am waiting UPS and the mail service.
hoptoad
Quote from: plengo on May 10, 2011, 10:50:21 PM
I just watched again and indeed at 2:52 to 2:55 where he connects the red cable, which is ALSO connected to the negative, to the positive of the battery for about 8 seconds (which should definitely melt the cable). See pics.
I don't know what this means. I am not saying it is a fake, actually I think it is for real, but something is wrong here.
Fausto.
Plengo, it looks to me simply that the output cable of the DC convertor is co-ax type. The outer black sheath has been removed for a couple of inches to reveal the outer wrap (made of aluminium foil or tin coated copper) conductor and the inner insulated conducter.
The outer wrap conducter has been unferled from surrounding the inner conductor and then retwisted and connected to a common negative on the battery.
It's colour is almost the same in the photo as the insulation on the inner conductor so it it gives the misleading impression that, from the red wire to the battery negative there is a direct connection via the white wire.
As both wires exit the black cable sheath, the whitish looking wire on the left connecting to the red wire is the inner conductor (still in it's insulated coating) and the whitish/greyish looking wire on the right is the twisted outer conductor connected to the negative.
Left and right are two separate conductors emerging from inside the single black cable from the DC converter output.
The inner conductor has been connected to the red wire shown which is only sitting on top of the black probe. It is not connected to the negative of the battery.
Cheers ..... at the least that's the way my bad eyes see it.
P.S. - Just been reading back through some posts and it looks like this had already been answered.
I hope I'm just as late keeping up when it comes to my own funeral !!  :P
Cheers
khabe
Quote from: David70 on May 11, 2011, 06:12:06 AM
@khabe
You even do not need 16 or 24 volts, the only thing you need is the tommyrot talking,
And of course you can change one big supercap to number of smaller sizes  - rersult will be the same or even better ;)
In reality your coil (pair of) unit gives out only few volts and you use DC-DC step up converter to get 12v,
Others will buy a lot of stuff, will spend the last family money for superalloy, for Metglas and for etc ... and everyone will wonder "why my replication does not work?"  >:(
And of course you need to be very resentful when someone surmise about hidden batteries or about invisible wires ... you must to be good actor, bringed to tears and after that you need to to blab out to someone from forum, that "two men visited you and offered ... millions ... oh sorry, I have no rights anymore to continue with public discussion.
cheers,
khabe
NB !!!
I do not accuse anyone - I just abridge one of scenario how it could be done, the OU  ::)
