Muller Dynamo
0 Members and 42 Guests are viewing this topic.
nul-points
Quote from: gyulasun on May 05, 2011, 06:11:47 PM
Hi nul-points,
I apologize for 'chiming' in, I do think a kind of regulator for voltage or current should be included in the feedback loop, otherwise either slowly or suddenly a runaway situation develops in the loop. A battery is an excellent such regulator and you can even abuse it to an extent but the moment you remove it from the setup and you do not care on some regulation, your setup becomes unstable for sure. This is why the input voltage (which is the output voltage from such a regulator) is to be kept under control.
rgds, Gyula
hi Gyula
no problem - i agree with you
when i first suggested trying diodes a few posts above i wasn't expecting that Romero would be able to remove the battery altogether
i'm not suggesting that it should be a permanent replacement without either a battery or some other regulator - just trying it as a go/no-go test would be sufficient because it would confirm if the 'feedback to source via diode' method, which we see so often in other designs, is an equally valid approach for looping the energy
thanks
np
http://docsfreelunch.blogspot.com
gauschor
The linked pictures posted by FreeEnergyInfo are confusing me. I would rather like to see the circuit made by RomeroUK :) or at least which pictures/circuits are really necessary to construct the device.
romerouk
Quote from: penno64 on May 05, 2011, 06:20:01 PM
Hi Romero,
I still can't believe IT WORKS !!! Its AMAZING !!!!!!
In the pic of the stators and rotor, you showed the nuts and bolts used to secure a I guess,
aid the magnetic field into the coil. May I ask how you secured the coils to the rotor when you replaced the bolts/screws and nuts withe ferrite.
Also, you mentioned multistrand mag wire for the cores. Can you be more specific, please.
Regards, Penno
oh my god ... :) a lot to answer tonight.
The coils are made of acrylic and all parts are acrylic - I used dichloromethane to glue them all.
Multistrand made of 7 wires totaling  0.8mm or 0.82mm, not 100% sure.
nul-points
Quote from: romerouk on May 05, 2011, 06:12:58 PM
@nul-points
I don't want to hear from anyone, steorn or others like them.This info is for all people and free too.
hi Romero
yes - i was just joking that Steorn will contact you because you have shown us what they have been *promising* us for years - and never delivering, it seems!  so maybe they need to ask *you* how to do it  :)
thanks for the feedback about the converter & stability
FreeEnergyInfo
Quote from: gauschor on May 05, 2011, 06:27:05 PM
OK...
SORYYYY..
CLER MY POST...
PEACE...
