Muller Dynamo
nul-points
Quote from: DadHav on May 12, 2011, 03:16:43 PM
If you want to see how the setup works without being in an airlplane you can see it on this video. http://www.youtube.com/user/DadHav#p/u/1/e0q8DDtjvMY
Hope this might help
John H (DadHav)
blimey - you don't want to be the wrong end of the runway, with one of those puppys approaching!!
wrt Romero's device, iirc someone mentioned in the region of 3000rpm
hth
libra_spirit
I have only read through about 1/3 of these posts, but I did not see anyone studying the vibrational characteristics of this motor/generator.
9 stator coils   8 magnets on the rotor
One rotation will produce
Coil pulses 8
Magnet pulses 9
Total pulses 72
At 5000 RPM which is 83.3 Hz, there will be a frequency of 6000 Hz generated on the rotor. Half the magnets will be retarding and half will be pulling and two will be neutral.
Each coil will receive 8 pulses, and each magnet will receive 9 pulses per rotation.
Coil pulse frequency will be 666.6 Hz
Magnet pulse frequency 750 Hz
The strong magnetic field will be moving in the reverse direction of the rotor at 8 times the RPM. It will also be moving along the coils at 9x the rpm, in the reverse direction of the rotors motion.
Are my numbers correct?
Dave L
phoneboy
Just a thought regarding the posts stating the runaway problem, didn't Muller also work on a thermo electric gen? Some of the replicators were speaking of using hollow ferrite bullets, if the bullets work, you could loop water or oil through them to cool the coils and at worst just use the heat for heating??
nul-points
Quote from: libra_spirit on May 12, 2011, 03:38:53 PM
Dave L
hi Dave
as one Libra to another, some of us have been attempting to get to grips with this, although i have to 'fess up and say that my contribution to the off-thread discussions has been with my hands over my eyes, under a paper bag over my head
however, one of the more intellectually gifted members of the team had started on the long and (coil) winding road of explaining (to me, at least) that there was even such a thing as a 'rotating magnetic field'
he did mention that 8X rpm ratio but shortly afterwards my other brain cell overheated and i started dreaming of a cold beer, i believe
tell us more about these things please
np
http://docsfreelunch.blogspot.com
DadHav
Coil pulses 8
Magnet pulses 9
Total pulses 72
Dave L
72 is correct I think and coralates directly to the number or cogs per revelution. With 10 magnets you would have 90, but is that good or bad?
