Muller Dynamo
0 Members and 52 Guests are viewing this topic.
khabe
Quote from: nul-points on May 12, 2011, 06:11:20 PM
John
from a frequency analysis of Romero's video when running without battery,
the spectrum shows a broad peak (of several hundred Hz width) centred on 188Hz
(over a 1 second snapshot)
however, if that was the rotor audio component then that would make it around 11000 rpm
i understand Ron to say that acrylic wouldn't cope much above 1000 without some re-inforcement
it should be noted that this rotor was apparently constructed from 3 or 4 layers glued together
iirc the run-down period is approx 100s
hope this helps
np
http://docsfreelunch.blogspot.com
Come on, nul, dont like you´ll kill somebody, 11.000 rpm ... have you any idea what it means ::)
It is not so hard to understand that Romeros rotor spins somewhere between 1250 ...1350 rpm,
cheers,
khabe
caccr2000
yssuraxu_697
Quote from: woopy on May 12, 2011, 05:13:47 PMi would recomand to use as much as possible  ( better sayd only ) all bolts and screws and axel   - . in plastic  or INOX = Stainless steel ,  to avoid magnetic interaction with the rotor.
Plastic = yes
Stainless & aluminum or any other CONDUCTOR = NO
Just take big chunk of either and bring close to rotor. Watch rpm / amp draw ;)
hartiberlin
Okay, here is the last movie,
where RomeroUK suspended his generator in one hand and
ran through his house.
http://www.multiupload.com/KC60FB6Z3Z
Again ZIPed MP4 movie file about 34 MB size.
Regards, Stefan.
DreamThinkBuild
Hi Caccr2000,
Interesting correlation.  :)
Thank you for sharing.
