Muller Dynamo
bolt
Quote from: kEhYo77 on May 31, 2011, 10:10:35 PM
Resonanceman, The video DID show those extra parts for coil shorting hanging under the table... @ 3:16...
What you see there is one of the coil SWITCHERS for the driver its not a shorter otherwise you will see two fets on each coil. In any case if there was ANY coil shorting going on anyway number one Romero would have told you about it as there is no point disclosing 75% of the circuit and second the dump cap would be charged to around 300-400v and not 15v. This rules out using a Maplin 12v DC switcher you must use a Laptop charger/adaptor 90 watts to 19.v then feed with 350VDC off the dump cap which then has the capability to run in excess of a 60watt OU load.
Remember coil shorting was what Romero was going to do NEXT so nothing to stop you making larger coils, bigger magnets with shorting and go for >60 watt looper. Then you have power of practical use which can provide deep cell battery charging and compete with a small solar power system and mains inverter instead of a TOY.
nul-points
which video?  'pre-self-runner', 'self-runner' or 'suspended-in-air self-runner'?
thanks
kEhYo77
toranarod
During recent tests I was pondering the possibility of using two paired sets of drive coils all wired in series configuration to be driven from the one pick up sensor.
As seen in the picture below, drive coils pair 1 is magnetically aligned to attract the magnets on the rotor disk. Drive coils pair 2 is magnetically aligned to repel the magnets on the rotor disk. This meant drive coils 1 and 2 would be wired in series to double overall inductance and coil resistance, consequently halving their power consumption. In turn this would give us the opportunity to create a repelling and attracting force simultaneously to the rotor disk.
The only technical issue with this configuration was working out the phase of the two coil pairs, so that when they engaged they did not electrically oppose each other in circuit.
This is where it got interesting…I experimented with the coils in phase with each other and out of phase with each other. When the two drive coil pairs generated a charge induced by the magnets and the polarity of the charge was in opposition to itself, drive current dropped to 25 m Amps.  Motor RPM was 1250. When I reversed the phase of the two coils motor RPM increased to 2200, drive current escalated to 180 m Amps.
I found this to be a very interesting result and something that needs a lot more work. I am posting this result in the hope that others may replicate this experiment and refine the technique.
nul-points
Quote from: kEhYo77 on June 01, 2011, 05:39:24 AM
@nul-points
This video http://www.youtube.com/watch?v=mEaY17NeK_I
it's not surprising if you can see some coil-shorting circuitry in that video - that's a video of Romero's Coil-shorting experiment - NOT his Muller Dynamo!
although Romero stated March 9th that he INTENDED to use coil shorting in his Muller rep, by the time he reported first results on April 7th he was getting COP = 2 already with no coil shorting
his device hadn't changed by May 3rd when he reported his first video of the device here
all the best
np
http://docsfreelunch.blogspot.com
