Power ratio over one
Started by handyguy1, January 03, 2008, 09:33:54 AM
handyguy1
Hay Stefan:
I just posted another you tube video.
The copper colored (15 gauge) air coil is the (electromagnet)driver coil (far left #15). There are only three sets (of 2 each) magnets in total (#11). One set of magnets are located above the driver coil, attached to the axle. If you were to take a battery and touch the driver coils two ends, this makes the driver coil an electromagnet, and the permanent magnets would respond by turning (about 90 degrees). If you turn the battery around and touch the driver coil ends (terminals) with the battery, the magnets would swing the opposite way.  This in turn makes the teeter engaging lever #4 rock back and forth because; it is attached to the same axle as the permanent magnets.
I just posted an early version of this device. There are two switches and two batteries. I originally used two switches and one battery with a diode, but the diode had negative effects. Notice how the permanent magnets don?t rock back and forth as much. It?s almost a vibration. There is a vast number of improvements in these devices!
The switching means on both follow the same principals.
A DC motor isn?t as efficient as the pulsed electromagnetic setup.
David
R_weng777
  Why is over-unity possible?  All energy comes from light,Eletromagnetism(light) when it strikes mattter(protons,nuetrons) seperates into electron-positron pairs,E-P pairs when they collide produce Quarks;  it takes 3 quarks to produce(P, N), matter combines and forms planets and stars, producing light,The circle is complete, not closed but open,infinte. The problem with this  is the higher the over-unity the more light is needed, a mini-black hole.Stealing fire from the sun or fire from heaven, sound familiar. The solution then is create your own light source.You can check the science yourself, the truth is out there.Ezekiel wheels was the design for my machine, but infinity might have some problem's,seeing is believing.
handyguy1
Hay Gyula:
I am using an old cheapie MM so I am sure you are right on the driver coil 2-4 ohms. My good one is being recalibrated. That?s why I said ?approximately? on the resistance. I have tried larger driver coils (more wraps) and the results are not good. I have also tried the green coils and the results are not good. I am still trying to explain to Stefan how the switches and driver coil work together. That new video has a cleaner view of the interaction of the switches and pulsed driver coil electromagnet. The newest video shows a faster and less of a rotation of the permanent magnets (this is the secondary device shown in the preceding videos. I am going to check out your links, thanks.
David
Speaking of overdriving, When the device is in operation, I grab the axle at the right end with my finger and thumb and can't stop the rocking motion. Just thought I would throw that in!
handyguy1
Quote from: R_weng777 on January 30, 2008, 11:12:08 AM
Hay R_weng777:
That is an interesting concept. I cannot comment on any of those theories they are  beyond my humble comprehension.
David
one
David
I have been thinking of  the  reciporcation  of your  device .
In  general  reciprocation  in  any machanical device wastes alot of energy .
Sense  you have found  that  reciprocating  is  better then  rotating  in this cae maybe  you can use  reciprocation to your advantage.
It looks to me  like you are applying  full power  the  entire   direction of travel both  directions.
If you  used another  set of  switches  and   cut off the  power  somewhere between  the  center of the  stroke and  the last 1/4 of the  stroke ....... you  would  be saving  a pretty big  chunk of    your input  energy .
OR  .......if your  switches are double pole ...... you might  be able to   use a capacitor .      and  switch the  capacitor  back and forth between  the  battery and the coil
anyway ........it is something to  think about .
gary
