0 Members and 76 Guests are viewing this topic.
Bruce_TPU
Quote from: blue_energy on January 16, 2008, 08:25:20 PM
Quote@ All
We finally heard back from our CA machine shop and Jason's, Hank's and mine is guarenteed to be completed Monday and in to mail to us.  So I will wait patiently (Not! LOL) and play this weekend.  I am going to make a cheap and dirty one until mine arrives.  I need something to do, and have my magnets and bearings.  Besides, I want to loosen the bearings a bit.  I am not going to post any video, unless I see something interesting.  The good news, is that the one coming is to exact spec's and materials.  I just need to find some N35's.  I, like Rob, am worried about this.
If anyone has a link to some, of our spec'd size, please post for all of us replicators.  Thank you.
Cheers,
Bruce
Hi Bruce,
I saw these and they looked like they might suffice.  They have one that's 6mm X 15 and N35 that seems to be just about how Al's were described.
http://www.monstermagnete.de/catalog/advanced_search_result.php?keywords=Z06
Hello Blue,
Thanks for the Link.  It will be good for our European friends.  I need a U.S. supplier.  K&J do not carry N35's.
If you find another, post it up.  Thanks!
vipond50
Quote from: lumen on January 16, 2008, 07:20:46 PM
Check it out!
http://www.youtube.com/watch?v=tknwdltnB6s
lumen
Excellent work, this is the best Ana so far. I copied video to review in more depth.
I noticed a small step on the top of everyother pulse, do U have an idea of what that is?
5 stars for u
Best Regards
DA
Quote from: lumen on January 16, 2008, 08:59:35 PM
@lumen
The stator makes a half turn for each rotor magnet it passes. As it passes a rotor magnet the stator changes to the other pole. (I need to confirm exactly the stator position wile passing)
I was thinking of the energy required to accelerate and decelerate the stator twice in each revolution.  Normally, to take a spinning object, accelerate it, then slow it down, repeatedly, does require energy.  A lot of energy.  To capture this energy from the stator is something I really think a long shot, I mean impossible.  To do so would probably only take power from the rotor, right?  But then ...
So are the magnets are transferring this energy back and forth?  As the stator accelerates, the rotor decelerates?  When the stator slows down, the rotor speeds up?  Regenerative braking comes to mind, although at near 100% efficiency?  lumen's work to put some info on the scope is interesting, can you put the acceleration/deceleration of the rotor on a scope at the same time?
I'm trying to keep my mind open.  This "anomaly" seems to be a new discovery, and it may mean something, if so, I am sure I do not know what.  This group is learning very fast.  Turning the stator "anti gearwise", is that the key?
Post more videos, everyone.  There are no failures, each effort increases the total knowledge if shared.  Don't hold back waiting for success (like some are), share everything, and truly work together, as a team.
Grimer
@ DA
"Turning the stator "anti gearwise (AGW)", is that the key?"
I think so. The reversal from GW to AGW is the point where the device goes from cycling around a portion of the BH loop in the power absorbing direction, widdershins say, (analogous the the Carnot refrigeration cycle) and goes around it in the opposite direction, clockwise (analogous to the Carnot power cycle). The change in the rotation direction of the stator magnet is a visible manifestation of the change in direction of the cycling around the chunk being bitten out of the BH loop quadrant.
Who is she that cometh forth as the morning rising  -  Fair as the moon. Bright as the sun  -  Terrible as an army set in battle array.
