Bruce_TPU
@ blue_
Thanks for the magnet links last night!
I have now ordered my N35 magnets.  Now I will be able to test with boths strengths.  I just have a funny feeling that the N35 is what is needed, and what was used.
It is obvious from Al's information that this is all about fine tuning, so perhaps with the N35, I can tune to the effect.   ;D  They will be arriving next week.
Cheers,
Bruce
CLaNZeR
Seems harder to get these new Stator Magnets to latch compared to the Bodged Stators I used before the correct ones turn up.
Spent a couple of hours inserting washers one at a time making the Stators Higher or Lower to try and get the easiest config and also moving the Airgap distance bit by bit, bloody boring stuff I will tell ya LOL
This was without the HDPE surround.
http://www.youtube.com/watch?v=bSMkHD3YGHU
Better Resolution at
http://www.overunity.org.uk/ocpm/tests/CLaNZeRSOCMPMMNewStators.wmv
Cheers
Sean.
Craigy
Unfortunately no replication can be a true replication. There are lots of un knowns.
The magnets on the rotor, Size yes , type no , test all neos in the size 1/2 by 1/4 inch, i.e n35 , n38, n40,
Find optimum stator spacing
Find optimum air gap
Find optimum stator hieght to rotor.
Be faithfull to the wieghts of rotor and stator.
Examine stators to find out what magnetic friction is present. Replacing bearings with better ones could alter the stator reponse curve to nullify the effect.
Lastly , the neos used in the rotor were old surpplus ones, Perhaps you need to take hammer to them to weaken them before installing. So if you think that in 2 days of testing you will get it to work all i can say is good luck
Any concepts or ideas expressed in this post are intended for the public domain. Free licence is given to reproduce and or modify provided it is for non-profit use. I don't want money, I want overunity!!
sveinutne
I have looked at Al?s and CLaNZeRS pictures of the magnets at the close passing.
Maybe this is the sync point where most of the action is taking place. The stator is almost brought to a stop at this point. When the rotor has past by some degrees, the stator is accelerated away from the rotor. Then the stator can turn 180 degrees before it is almost stopped again by the passing of the next magnet. This is the case if the stator is rotating 4 times faster then the rotor, when we use eight magnets on the rotor.
If the stator is turning much faster the magnet can turn 180 degrees plus n*360 degrees. So the next sync speed will be 12:1 and then 20:1.
Al mention that he could make the stator sync at 4:1 and 12:1, and that fits nicely with this theory.
I am looking forward till the day we get detailed info of the position of the stator magnet between to rotor magnets.
Svein
CLaNZeR
