TheOne
With this new video version I posted in my previous post
in the video at aprox 0:38 he show this (circle in the image)
he tell its 2 magneto kinetic Jetson damper?
What is that!!
naklaw
Quote from: CLaNZeR on January 06, 2008, 03:56:00 PM
In the original Video from AL he has 3 stator magnets.
2 at the front are left alone to spin and be influenced by the Rotor.
What he then does is spin the Stator at the back the opposite direction, the stator keeps moving the same way as do the two front stator magnets. When the back Stator has sync'd with the Rotor it seems to hold a steady RPM and then by releasing the breaking effect of the two front stator magnets, the Rotor accelerates to over twice the speed.
It is good to be sceptical, but at the same time too try and copy how he achieves the effect.
At the moment you just have 1 stator. If you spin your rotor you seeing it turns the first stator, now spin the rotor and spin your stator the same direction, see the difference it has? Now add a couple more and play :)
On your Rotor do you have the Magnets SS-NN-SS-NN etc etc
I will buy smaller bearings tomorrow. As can be seen on my pictures, the board has place for three stators, I will try this with the smaller bearings.
Yes, they are mounted SS-NN-SS-NN etc
My stators will be separated by 120 degrees... I don't know any of the parameters/dimensions of the original device :(
Should the stators have a larger inertial mass? My current stator has only a few grams of mass.
naklaw
Quote from: TheOne on January 06, 2008, 04:09:54 PM
What is that!!
"The variant in the video uses the magnokinetic Judson dampers to achieve the same effect of retarding the stator magnet at the critical instant"
"the magneto kinetic Judson Dampers keep the stator magnet at 5000 RPM"
TheOne
Quote from: naklaw on January 06, 2008, 04:16:09 PM
What is that!!
To achieve the same effect like the 2 stators he stop at the middle of the video?
tbest
Quote from: TheOne
What is that!!
Rogowski coil?
