Bruce_TPU
Quote from: blue_energy on January 18, 2008, 01:28:09 PM
QuoteThe very fact that ANYONE would build something like this, and pour pessimism, evading the possibility of OU so vehemently is ridiculous. I would pee my pants as I think most of you would if you could make this thing run like in his video.
@unzapped
I think Als statement on Jan. 5 is a reasonable, skeptical, scientific way to look at it:
Please, no theorizing until we know the facts.
It spins, we don't know why, it's probably a worse mistake than even Steorn made.
Later I will be able to explore the issue further.
All this talk about Faraday meeting Saul on the road to Damascus makes me nervous.
QuoteHe already put up one video, a second better video would be very easy.
True.  It would be easy.  And if he were in the process of attempting to convince everyone that he has discovered the key to mankind's energy needs forever - it would be odd if he did not.  But, he's not trying to convince anyone of anything.  I suspect, at least, that he doesn't care what anyone else thinks.  Big Claims require Big Proof.  He has resisted the urge to bias his judgement by concluding anything until more research has been done.  He's asking us to allow what we see to be relegated to the realm of the unknown until there is more evidence.  Real science is stepwise, patient, and often boring.  As to why he hasn't made progress on it lately: he has said he has pressing commitments at work that demand his time.
QuoteReplicators keep on keepin on, but beware you may have nothing more than an interesting toy and a sore finger....
You may well be right about that.  But, the only way to know for sure is to experiment and see.  Any replicator who is only doing it because he 'knows' he's going to witness overunity - may well fail whereas those who are merely attempting to document the truth about this fascinating effect - are more likely to find it, whatever it is.
Hi blue_
I could not have said that better!   ;) :D ;D
The sound of reason is always music to my ears!!  LOL
Happy experimenting we will go, indeed!
@ Sean
Very nice video.  Great promise.
Perserverence is not measured by the number of hours or days, but by the steady, patient tuning, of a man on a mission.  Thank you for showing continued diligence.   ;)
Three more of us will quickly be joining you.
Warm regards,
Bruce
Bruce_TPU
CLaNZeR
Quote from: Craigy on January 18, 2008, 03:31:54 PM
Mk2 in production , when will i learn lol..
Looking good mate.
Cheers
Sean.
http://www.overunity.org.uk
Yadaraf
Quote from: CLaNZeR on January 18, 2008, 03:47:40 PM
Quote from: Yadaraf on January 18, 2008, 02:37:35 PM
@ CLaNZer
I noticed that you have taped the OD of the rotor -- presumably to improve aerodynamics.
Al did not tape his rotor, and it's possible that subsequent air movement within the channels created a static charge.
Comment?
The Tape is to black out the edge with a reflective strip attached for the Tacho.
@ CLaNZeR
Is it possible that air flow through the rotor channels develops static charges?
Does the tape in your model need to block the channels, or can the tape be applied only to the area beneath the channels?
Thanks...
jwk
Everyone attempting to replicate this device, before you go any further you really need to ensure you have read this thread (below)  from start to finish (finish being a few day's after the video was released). There are many things mentioned on this thread that not all replicators appears to have picked up. height and distance of stators included.
http://www.steorn.com/forum/comments.php?DiscussionID=59687&page=1
