0 Members and 80 Guests are viewing this topic.
RunningBare
Quote@alsetalokin is still evading the answer to this simple 'yes' or 'no' question. He thinks he doesn't owe the answer to anyone but he actually does if he wants to preserve his integrity.
"chuckles"
alsetalokin is in a good job, he gets paid well....and more importantly he is an anonymous internet user, I'm sure his integrity where it really matters is fully intact.
Omnibus
Quote from: RunningBare on January 19, 2008, 07:38:39 PM
"chuckles"
Don't be so sure. If he were my employee or a grad student and I knew his current behavior that won't be so and I'm not alone in that.
ken_nyus
Quote from: Omnibus on January 19, 2008, 06:26:14 PM
@ken_nyus,
You may have a point. I've noticed difference in behavior and probably easier appearance of the effect when more than one stators are forced AGW.
You noticed a difference when you tried stators equally spaced, like at 90 degree intervals or 180 degree?
(rather than the original 27.7 degree intervals)
Or just when you tried more than one?
leeroyjenkinsii
Overunity is like the search for bigfoot.
vipond50
Quote from: HyTower on January 19, 2008, 07:06:29 PM
To vipond50
Can you tell me what stator bearing you started out with and what you are using now when you get the three stators to sync.
Also it might be just the camera, but the rotor mag look somewhat different, are they the 1/4 by1/2 round that are in most of the spec i have seen
thanks and keep up the good work
HT
Hi Hydro
Sure Glad to help
1. The Stator bearing is a R3-HA! manufactured by Bearings. This right off the box
2. The two bearings have a small thin washer" will mic " between them and another washer to give clearance off the base plate Will also get a Pic of the assembly layed out.
3. The Rotor mags are 1/4" diameter and 1/4" long N42's. I stacked them up (four) to give the length u see.
Hope this helps
I machined a longer adapter to house the bearing
