Omnibus
@btentzer,
Where did you order there N35 from?
Omnibus
Quote from: ken_nyus on January 20, 2008, 06:50:25 PM
Were you guys able to find stator bearings the same size as Al's?
ID 0.1875, OD 0.5, and 0.125 thick?
That seems to be a hard exact size to find.
Also are these bearings with shields and lubrication/grease inside, or no grease, no shields (you can see the balls) and free running?
The part number of these bearings is R3. I made an error above calling them bearing magnets. Sorry about that. Those with no lubrication inside and shields are faster although there's a certain wobble due to the balls. The wobbling is there with the shield as well. I don't think this is an issue.
Bruce_TPU
Quote from: Omnibus on January 20, 2008, 08:35:57 PM
@btentzer,
I am out of town on my laptop, not my home computer with the info.  But it was the company in Washington, that Blue_ posted the link too.  He posted two links, but this fellow called me back and had great customer service.  The were $1.05 each, plus shipping.  Same size as what we want, 1/4" by 1/2".
I ordered 10.  They will be here this week.  I already have my N42's on my play model.  I am also staying with single bearing stator's but upgrading to double precision (two steps up from what Bill, Jason, Hank and I, now have.)  I will test with both.
You or someone here can go back and search the two links from blue, or wait till I arrive home tomorrow evening and I will happily post it for you.
Cheers,
Bruce
Omnibus
@btentzer,
Thanks. Will wait. I've already ordered N38 but won't hurt to have these N35's as well.
Another thing I'm finding to be quite important is the fixing of the rotor magnets in the grooves. Slight disparities seem to make a great difference in the behavior of the rotor. I'm reluctant to glue them because that won't make easy to exchange them. Had them press fitted into the grooves after sticking a piece of duck tape to them. I'm finding out now that isn't precise enough positioning..How do you fix them in place into the grooves?
Bruce_TPU
Quote from: Omnibus on January 20, 2008, 08:58:49 PM
@btentzer,
In our professionally machined rotors, they will be press fitted.  In my rough and dirty toy, I simply placed some electrical tape over each opening to hold them in place.
Cheers,
Bruce
