0 Members and 23 Guests are viewing this topic.
hydrocontrol
Quote from: RunningBare on January 21, 2008, 09:52:18 AM
Hope this might be of help
I used my sound card and constructed a transducer consisting of a ferrite core and around 20 turns of copper wire, the measurement is taken approximately 1 inch from the stator while I maintained AGW lock by spinning the rotor manually.
What your seeing is 2 cycles of the stator.
http://cosmopod.com/mysite/barefm/op/stator2cycles.jpg
!  O   []
Exclamations represent rotor edge.
"O" represents stator
[] represents transducer
And here is a 28 second audio sample
http://cosmopod.com/mysite/barefm/op/statorwave.rar
Wow.. that is a cool solution. Interesting graph. It would appear that the field is not symmetrical or the spin is not symmetrical. humm.. Could it be so simple as to glue a chunk of paper clip to the stator to warp the field ? I have wondered how symmetrical Al's stators magnets are. Could it be that they are not perfectly diamagnetically formed and that the field is slightly tilted from the axis ? I think someone else suggested tilting the stator magnet. Guess it is something else I will try tonight with my setup.
Bruce_TPU
Good morning, All,
Last night, at about 2am, I realized a simple test, based on Al's video, to determine if our rotor magnets are close to matching Al's.
If you recall, in Al's video, after he sync's the one stator AGW, soon after, he stops, by hand the other two stators.  Okay, now, if you watch the two stopped stators, when Al removes his hands, they DO NOT start to respin on their own.
TEST:
My test is this, to all replicators.  Spin up your rotor by hand, and then manually stop the two identical stators, with your hand, and then let go.  Does your stopped stator's begin to respin??  If yes, the rotor magnets are stronger than Al's!!    :o
Please post your results and magnet strength of rotor magnets.
Cheers,
Bruce
EDIT:
I have already done this test, on my "toy".  And they did not like being stopped, at all, and immediatly began to respin!!
Omnibus
@btentzer,
Same here. Mine didn't like to be stopped either. Both stator and rotor magnets are N42. Need to replace the rotor magnets with N35.
PolyMatrix
@btentzer
Good thinking.
May I point out that the rotors spin at low speed but not at high speed.
Speculation: the high speed of the magnetic field passing the rotors is too quick to overcome the moment of inertia in the stopped rotors. Sorry I have a bad habit of stating the obvious.
Omnibus
@btentzer,
I was just gonna say that.@PolyMatrix beat me to it. Try spinning the rotor at higher speeds and see what happens. As I said, if I spin the rotor the way @alsetalokin does, the stators don't like to be stopped. However, if I spin it much faster, and remember he holds the two stators after the rotor has accelerated, my two stators remain at rest, only slightly trembling.
