0 Members and 45 Guests are viewing this topic.
Omnibus
So far most of us have succeeded in latching the lone stator AGW. That latching was the "mistake" which @alsetalokin made which he says led him to success. Obviously, however, there something more to it because no one here can yet see the self-sustaining spin despite the AGW latch. My next step will be to exchange the current N42 rotor magnets with N38 and then with N32 ans see if this would make any difference.
Bruce_TPU
@ All
Please take a look at the :20 sec mark of this version of the OC MPMM.
Take note, that when Al spins the stator magnet located between the dampers, that the rotor does not spin.  You can also see this at :39 sec mark.
Notice that when he turns lightly, both of the other stator magnets, the rotor also spins.
So, we too want to see this effect with our setup.  Moving the stator between the dampers and the rotor does not spin.  Conclusion:  If it does, our rotor magnets are too strong.
Any thoughts??   :-\
http://www.youtube.com/watch?v=E2Ck9xC4S44
Cheers,
Bruce
PolyMatrix
At the 20 second mark the non-spin you noticed is between the two bar magnets. That is it happens on the sharp end of the octogon.
Omnibus
@btentzer,
I forgot whether or not you have a setup yet to play with. If you do you'll see that behavior of the stator magnets immediately. They don't spin uniformly but each one has an extended period of rest while the rotor is moving.
PolyMatrix
@Omnibus
In the 6 balls Sinkscience vid it also occurs to me that it is a study in Inertia.
