RunningBare
Quote from: sterlinga on January 23, 2008, 12:15:58 PM
Unless these statements were not intended to mean what they imply, to me they describe at least a small degree of success in four separate cases.
Sterling
I suggest changing the wording to "A degree of success"
ken_nyus
Quote from: RunningBare on January 23, 2008, 07:18:53 AM
Posted by pcstru4 on the steorn forum
What I envisage is that the stator magnets having been mounted below the plane of the rotor magnets are lifting the rotor and relieving the vertical load on the bearings, resulting in a sudden loss of friction from the bearings. For this to work the amount of lift is critical - too much and the bearings will load up as the balls hit the top of the race, too little and the rotor won't lift, get it exactly right and it could be goodbye bearing friction. IMO a minimum of three stators are needed for this to balance the lift around the device and 'looser/slacker' bearings might be beneficial. It should be possible to reproduce this effect without having to achieve an AGW lock, by just spinning up the rotor and stopping the stators so that they are oscilating but not rotating, but the speed of the rotor will need to be high enough otherwise the vertical oscilation will become too large, it also needs to be slow enough for the oscilation to become large enough but a rotor running to fast will not be so bad as it should hit the zone at some point.. The revealing data is simply elongated winddown times from a fixed value RPM start or if your getting close, a change in accelleration (-) slope.
Certainly something to consider.
Hey RB,
But that d*mned acceleration, what will account for that?
That is the big mystery that keeps me interested.
dean_mcgowan
@All,
Does anyone of these replications have quantitative results (sorry OB) to support the acceleration claim ?
Cheers,
Dean
RunningBare
Quote from: ken_nyus on January 23, 2008, 01:05:32 PM
Hey RB,
Well, I had a long boring reply for you about less friction at the right moment, but on trying to post I got the usual
Lost connection to MySQL server during query
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /mounted-storage/home71c/sub001/sc11940-GNVW/overunity/Sources/Subs.php on line 321
Warning: mysql_error(): supplied argument is not a valid MySQL-Link resource in /mounted-storage/home71c/sub001/sc11940-GNVW/overunity/Sources/Errors.php on line 123
Warning: mysql_errno(): supplied argument is not a valid MySQL-Link resource in /mounted-storage/home71c/sub001/sc11940-GNVW/overunity/Sources/Errors.php on line 124
I cannot be arsed to type it all out again.
dean_mcgowan
RB
Hitting the back button usually retrieves it for me.
Unless your using a DOS based browser :S
Cheers,
Dean
