MeggerMan
@Jason,
I think the best way to monitor the dynamic rotation of the stator is to use the optical encoder wheel from a mouse mounted atop the stator.
You can even use the sensor from the mouse with the wheel and no drag.
Rob
Bruce_TPU
Hello All,
I have received my N35 magnets today and did my separation test, in a clear tube.  I tested six times, three times with one pair of magnets and three times with another pair of magnets.
N35 Separation:
28.5 mm = N35 magnets
Al's Separation:
30.5 mm = ?
N42 Separation:
34 mm = N42
I think N37 or N38 are the next ones to order and test.
@ Omni
Did you order either of these sizes?  Has anyone else?
My bearings did not arrive today, hopefully tomorrow.  Also my machined parts should arrive by Friday.
@ Clanzer
I am interested in you damper test when you have received the identical material that Al used for dampers.  If there turns out to be a difference between Al's material, and the Aluminum we are all using, we will need to switch this to the same material as well.
Cheers,
Bruce
Omnibus
@btentzer,
I ordered both N38 and N35 but am still waiting for them to arrive. The observation you present is very interesting. We should really try to keep the parameters as in the original.
On another note, do you know who made this simulation. If I remember correctly you posted it at one time: http://www.geocities.com/deasyart/steorn/OC_sim_one_stator_a.JPG What I'm curious is what is the stator to rotor field strength ratio used and at what ratio the effect ceases to appear.
Omnibus
@btentzer,
Can you measure the separation between NN as well as SS. There's a difference with mine. Recall also the data I posted several pages back, the kgauss weren't the same on both poles.
crash_uni8
does anyone know a simple way to make the 3 stators? :-\
i haven't a clue right now....
