0 Members and 97 Guests are viewing this topic.
Bruce_TPU
Quote from: Omnibus on January 23, 2008, 07:24:26 PM
@btentzer,
I ordered both N38 and N35 but am still waiting for them to arrive. The observation you present is very interesting. We should really try to keep the parameters as in the original.
On another note, do you know who made this simulation. If I remember correctly you posted it at one time: http://www.geocities.com/deasyart/steorn/OC_sim_one_stator_a.JPG What I'm curious is what is the stator to rotor field strength ratio used and at what ratio the effect ceases to appear.
Sorry, I can not remember.  I saw it on one of the many Steorn threads about the OCAL Motor.
Quote from: Omnibus on January 23, 2008, 08:30:30 PM
@btentzer,
Can you measure the separation between NN as well as SS. There's a difference with mine. Recall also the data I posted several pages back, the kgauss weren't the same on both poles.
I am not sure the "practical" way to do the requested test.  Give me a guide line and I will give it a go in my next spare moments.
Cheers,
Bruce
Omnibus
@btentzer,
Schematically it should be like this:
Measure the separation in this way first
S
N
separation to be measured
N
S
and then this way
N
S
S
N
With my magnets which are supposedly N42 the first measurement gives something on the order of 27mm while the second measurement gives 33mm for the same pair of magnets.
Bruce_TPU
Gotcha.  Thanks!
I will post it tomorrow evening.  Right now my paint is drying.  I painted all of the North half's.   ;)
Cheers,
Bruce
georgemay
Not sure if anyone noticed:
ALSETALOKIN
Can you spell it backwards? :D
