CLaNZeR
Quote from: A-Z on January 24, 2008, 05:49:50 PM
Quote from: Omnibus on January 24, 2008, 02:22:37 PM
Speaking of femm we have to find out who did the simulation @btentzer cited once: http://www.geocities.com/deasyart/steorn/OC_sim_one_stator_a.JPG
hdeasy on the Steorn forum.
Hugh also posted this today at:
http://overunity.org.uk/forum/index.php?topic=71.0
Sean - I had some time after all and could make the following comparisons to show
how sensitive the gain is to parameters: well, okay, some of the changes to go to Al's setup were a bit large:
I will now try to see how far I can 'bend' my old sim to Al's setup whilst retaining a gain.
My 'old'setup
Strength of rotor magnet/ Teslas  -----------------------    0.05
Strength of Stator magnet/ Teslas   -----------------------  0.20
Viscous lag time / Sec        -----------------------        0.001
Radius to outer rotor pole / m -----------------------       0.100
Radius to inner rotor pole / m  -----------------------      0.085
Radius of Stator magnet/  m -----------------------          0.025
Initial Stator angle / Deg  -----------------------          20.0
Mass of rotor / Kg   -----------------------                 0.200
Mass of stator / Kg ------------------------                  0.0025
*KE Gain / Joules   after 6.5 sec          0.018*
-------- Al's setup -----------------
Strength of rotor magnet/ Teslas  -----------------------    0.10
Radius to outer rotor pole / m  -----------------------      0.072
Radius to inner rotor pole / m -----------------------       0.052
Mass of rotor / Kg   -----------------------                 0.254
Mass of stator / Kg  -----------------------                 0.010
Al's setupKE Gain: Negative for inital stator angles 30, 40, 50, 120, 210, 300, 330 deg.
(though for some of these the rotor spun down,  giving peaks of gain of about 0.01 J briefly (just PE -> KE -> PE peaks)
  before the gain is converted into a loss of hundreds of Joules!)
The mass of the stator was the first parameter I tweaked to go from my 'old' sim to the OCAL one. In the old sim, it was rather low at 0.0025 kg. A figure quoted for OCAL has been 10g (5g for the magnet and 5g for support, holders ec.). It seemed unrealistic to have anything much lighter, so I set it to 10g.
However, with this heavier stator the gain disappeared!!
Thus it seems the gain is very sensitive to weight of stator. It would be good to get it down as low as possible. Since you had to zonk it up with blue-tack, you might have had a light stator to start with: I would take off the blue-tack if I were you.
In order to balance the heavy stator, I thought to increase the rotor weight. At 400g, the gain was there again ! But it was only 0.0015J - less than a tenth its previous value. If I increased to 800g I got 0.004J and there was little to be gained by increasing rotor weight further. So I adapted a weight of 800g to be consistent with stator weight 10g.
Next magnet strength was considered: my old sim had stator stregth 0.2T - which I believe is what OCAL had. But my rotor strength was only 0.05 Teslas. I now increased it to 0.10 Teslas, which I believe was closer to OCAL's value. This had a positive effect on the gain, increasing it to 0.017 J : almost what we were getting for the old sim.
By the way - I always have start speed of rotor about 190 RPM and set stator to be always in 4:1 AGW synch..
I am sure Hugh will not mind me posting this here,
Cheers
Sean.
http://www.overunity.org.uk
Omnibus
Could you ask him to come over here to discuss his modeling? Thanks.
MeggerMan
@Sean,
PM sent (forgot to mention length, whatever you think is best - about 12-14mm ?)
@Omni,
N42's all K&J, N38 ebay
Only thing I can think is you have some very powerful magnets near your testing area. ;)
(perhaps the other N42 magnets)
Have you got some magnetic film for field testing, it may show a skewed pole, in that the pole is coming out the corner of one end.
How many pairs are like this?
Rob
Omnibus
Thanks @CLaNZeR. So let's start from this--the simulation of @alsetalokin's was for 1kgauss for the rotor and 2kgauss for the stator. Was that induction considered to be at the surface of magnets or elsewhere?
CLaNZeR
Quote from: Omnibus on January 24, 2008, 05:51:47 PM
@CLaNZeR,
The guy should know better than that. The abuse will evaporate and the abusers will have to eat their hats if independent parties happen to reproduce the effect. Therefore, it's in his best interest to be as cooperative as possible.
Sorry Omni
Life is not as clear cut as that mate.
People in life have different sensitive levels and what may seem to one person a reasonable, clear to the cut question can indeed offend another.
To the person asking that question they see nothing wrong in what they have asked, to the person being asked it can make hell of an impact.
EXAMPLE: Omni I know you and I know how you ask questions to get what you need too know, in the logical way you need too know and when I see a post from you that makes me cringe I know it gets other peoples back's up, but I just accept it and think, well that is OMNI and that is his way of asking stuff.
I do not get offended because I know you by now. Yet others will get really annoyed at the direct approach you have and will not be as forward with the answer, because you did not take time to get to know that person and also to get too know how to ask the question. Get my drift?
Interaction is not always about facts and good to remember that this OU stuff is not business orientated, it is a hobby to most people and they give what their spare times allow them to give, so we should not expect anything of anyone.
If AL was claiming OU and asking you to send money, then yep everyone has a right to ask questions, that is not the case here though.
Cheers
Sean.
