evil-doer
Quote from: blue_energy on January 25, 2008, 12:36:33 AM
So - you think the rotor is moving 270 degrees between each frame?  That would make sense too.  That would also mean that the stator is revolving 1080 degrees between each frame.
no i think its spinning several times around on each frame. if it was only 270 degrees, say it was filmed at 20 frames a second. thats only 900 rpm. its probably spinning around 5x270 degrees for each frame
geodan
Quote from: evil-doer on January 25, 2008, 12:44:35 AM
are you saying that it's more then 4:1?
Omnibus
When I count frame by frame 1s is the 25th frame.
evil-doer
Quote from: geodan on January 25, 2008, 12:54:15 AM
no the stators are spinning many times around too. its 4:1
Omnibus
As far as I can see visible full turn of the stator (restoring the initial black-white position) takes about 120 frames, that is 4.8s.
