0 Members and 18 Guests are viewing this topic.
evil-doer
Quote from: Omnibus on January 25, 2008, 01:58:08 AM
What rpm is he measuring in the first video anyway? Seems he's pointing the laser dot to the stator and when the effect kicked in it showed something on the order of 1300rpm. Then, when he stopped the two stators it again seems that he points the laser spot to the AGW stator and the rpm now read over 4000. Is this the way you understand it too? Is he measuring the rotor rpm at all in the first video?
no he says almost 5000rpm on the small magnet
so even this 3465 seems too high. at 4:1 thats 13860rpm on the small magnet.
so either we are working this out wrong or he has ramped up the speed considerably with tweeking
Omnibus
@evil_doer,
Correct, the data he's showing in the video refer to the stator, 5000rpm he says although the readout seems to show somewhat less. Give or take around that number. OK. I don't get the rotor rpm, though. Something is messy before he stops the two stators and after he stops them he seems to measure only the AGW rotor rpm. If he's showing a greater effect now in this third video that would really be something. I'd happily live even with the effect from the first video.
dean_mcgowan
Is there any indication of acceleration/deceleration on this video?
Bruce_TPU
You know, it could be that he is having both stator magnets running AGW.  If you recall, he said that the Stator went over 12,000 rpm when two of the stators were synced AGW.  This would explain and match the rpm's we see in this video.
Cheers,
Bruce
CLaNZeR
Quote from: geodan on January 24, 2008, 08:47:03 PM
Can you please comment on this? it sounds like tolerances need to be pretty exact... Several of us are about to order rotor's / bases based on the drawings that CLaNZeR refers to here... do you feel that adjustments need to be made before we place the orders?
Hi Geodan
Ignore that base layout, it is my crappy Software. I created a middle line and told it to increment every 27.692 degrees and the software created the drift.
When and did it a different way this morning all all okay.
I also overlayed JDO's Base DXF on top after I had finished and it was spot on, so no problems.
Cheers
Sean.
http://www.overunity.org.uk
