vipond50
Quote from: Bruce_TPU on January 25, 2008, 11:47:52 PM
Hello All,
Well, the good news (for a moment!  LOL)  Was that my machined parts came in.  I put it all together, and started to look for some of the things I had seen on my self built wooden one.
I notice that my stator magnets simply stuttered as I rev'd up the rotor.  And then I measured the distance from edge of Stator, to edge of rotor.  Distance was 8 mm.  It should be 5 mm.
To make a long story short, they cut Hanks, Jason's and my rotor 3/8" short.  Go figure!   :(
Hank is going to have him recut and resend our proper sized one.
The base is correct, and my stators are great.  N35 magnets.  Bearings for the stators are super precision ABEC 7's.  Very nice feel to them.  Dual rotor bearings, very nice.
Concerned about slippage where the delprin slip over the stator bearing.  But I will wait for new rotor before addressing that.
So we wait another few days.   ;)
Cheers,
Bruce
Nice rig Bruce, really to bad they muffed the rotor Dee's. Hoping for success for all.
Take Care
Bruce_TPU
Quote from: crash_uni8 on January 26, 2008, 12:06:33 AM
@Bruce_TPU
i hate to bother you but could you post a picture of one of your stators....or explain how they are put together
ive been having the worst time figuring out how to make them.... :-[
Hey Crash,
Base is threaded for 4-40.  I use a 1" 4-40 brass screw through the ABEC 7 bearing.  The head holds the inner race of the bearing firm.  A brass nut goes on the other side of the bearing and is tightened.
This then is screwed into the threaded base, until the brass nut contacts the top of the base.
The circular N42 magnet is glued inside of my delpin holder (Great Job on that Hank!) This then is placed on the bearing, which fits snugly into the bottom of the Delprin.
JDO300 has drawings that show that part.  If someone could put together an assembly diagram, that would probably help some of the replicators, as well.
I hope that helps!  (If I had DSL, I would post lots of pics to assist.  It just takes too long with my dial up)
@ Bill
Thanks.  I too hope for success.  I really think N35's or N38's with better (not heavier) bearings should help.  Have you had any more time to test?
Cheers,
Bruce
Mr.Entropy
Quote from: niente on January 25, 2008, 03:08:48 PM
Here's a simple analysis (by using FEMM) of the torque of the rotor covering 45 degrees of the motion (then it repeats itself because of the symmetry).
Your boundary is way too close for FEMM to give you accurate torque readings.  I think you'll find that the extra torque disappears when you move it far away.
Thanks for providing the source, though!
Cheers,
Mr. Entropy
Bruce_TPU
OK, I just ordered some 6061-T6 Aluminum Alloy, from:
http://www.discountsteel.com/index.cfm/go/main.itemDisplay/itemID/54.htm
I believe that the softer, pure aluminum bar from Home Depot, will dampen too much, (excess of eddy currents, too much braking applied).  The alloy has not just Teflon, but also copper in it's composition.  So the braking effect will be identical as with Al's setup.
I believe that Sean's test will show a longer run time with the alloy.  (even if not by much, for the wind down test.)
Cheers,
Bruce
vipond50
Quote from: Bruce_TPU on January 26, 2008, 12:25:16 AM
@Bruce_TPU
Hey Crash,
@ Bill
Cheers,
Bruce
@Bruce
In the middle of a New rig with different Mea's for the radius, of coarse it is base off Al's spec's, So when the time comes we'll see. I'll post  the data regardless of the out come.
Also waiting on parts too ........
HI Ho, Hi Ho off to watch a Movie I go
Later Bill
