CLaNZeR
Quote from: Omnibus on January 07, 2008, 07:49:43 AM
Is that bearing good enough: http://www.raidentech.com/11h04-08.html
It does not really give a spec on that link.
The ones I have used are MF63ZZ 3X6X2.5 from http://www.technobots.co.uk/acatalog/Online_Catalogue_Miniature_Flanged_Ball_Bearings_385.html
But I am doing it different too the way AL has monted his Rotor.
If I find the Top bar is a hinderance then I will probably mount the bearings in the Rotor and use a shaft poking up from the base as AL did.
I will mount the Stator bearings using the 3mm Flange bearings also but they will be on shafts.
Worth doing a search for flanged miniature bearings as over in the states you are going to be spoilt for choice I reckon.
http://www.overunity.org.uk
Bruce_TPU
Quote from: Jdo300 on January 06, 2008, 10:10:06 PM
Hi Everybody,
I can see that there is quite a buzz going on here concerning Al's device! I have finished the 3D CAD model and am currently making some dimensioned drawings for those of us who don't have AutoCAD or a CNC machine laying around. For those of us who do, I will be posting the CAD files as I said before.
I am still waiting to get confirmation about the diameter of the rotor disk. I saw the other 3D renderings that were posted and they look nice but if you take a look at the slots in the rotor disk, they look the same as the drawing that I labeled incorrect. I'm just about ready to post the drawings but I need to know which image is correct. (for those of you wondering what I'm referring to, here's a link to my post earlier in this thread):
http://www.overunity.com/index.php/topic,3871.msg68313.html#msg68313
The sooner I can get this straightened out, the sooner I can post the information.
God Bless,
Jason O
Hi Jason,
I found this from a quote of Al, in the Peswiki .txt file named Judson.
"That's good, because I just invented them yesterday.
Magnokinetic because that's what they are damping;
dampers because that's what they do; Judson, because,
well, somebody I used to know went to high school there.
A dimensioned sketch of the bearing/magnet holder assembly is posted on the other site. The baseplate that I am using is acrylic plastic, 5/8 in thick, 7 3/4 in x 8 1/2 in,
with a 1/4-20 threaded hole in the center for the rotor axle, and 13 evenly-spaced 4-40 threaded holes for the stator magnet bearing holders, on a circle of radius 3 3/8 in centered on the axle.
The rotor is 3/4 in thick piece of HDPE plastic, 2 7/8 in radius, with a 0.500 in center hole bored all the way thru for the flanged axle bearings. Magnets are held in 8 evenly-spaced 1/4 in wide slots, 7/16 in deep, inner edge of slots at the 2 1/2 in radius from center.
This is the basic layout for the 13x8 version that I am experimenting with. But I am mostly just using 3 stator magnets and a couple of "dummy" aluminum pieces of the same size as the magnets, also mounted in the same type of bearing holder.
The stator magnets are mounted by a single trimmed 4-40 SHCS and a little washer to make sure only the inner bearing race is contacting the screw or the baseplate.
The rotor magnets are press-fit in place."
I hope that helps you to finish the CAD drawings.
God Bless,
Bruce
CLaNZeR
AL's reply to regards jdo's question:
My practice on prototyping is to whittle and gnaw on things first, big non-critical dimensions may be only approximate, then when I am forced to draw or otherwise document things, I " rationalize" these dimensions.
So if the rotor blank comes out 4.878 or something weird like that once I've got it faced and trued, that's fine for prototyping, but I am most likely to rationalize that non-critical dimension and make it 5.000 on the drawing or documentation.
You follow?
Sorry if that throws anyone off. I am aware that you folks are doing photogrammetry over there, believe me it isn't necessary.
Here's an actual set of measurements made right now:
Material HDPE
rotor diameter 144 mm
rotor thickness 18 mm
distance from OUTER EDGE of rotor, on a radius, to INNER EDGE of magnet slots 13 mm
slots are symmetrically arrayed, 1/4 " nominal width, 12 mm depth
slots cut in a single pass with a 2-fluted end mill 0.250"
I hope that helps.
Jdo300
Hi CLaNZeR,
Thanks! That clears that issue up now.
Now, there is still one thing I don't have information about and that is the metal plug in the center that he mounted the 3.5mm bearings in for the rotor. As I understand it, he just used a screw with press-fitted flange bearings in an earlier model. I am interested in knowing if that would be sufficient for it to work or if the added stability from the machined bearing plug is necessary. If so, I would like to get more information on it to include in the blueprints. At the moment, I just have a 1/4"/ 20 bolt for a shaft in the 3D model with the press-fitted bearings.
Could you also pass this along to him?
@Omnibus & Everyone,
I noticed some have questions about the rotor magnets. If you look at the overlaid drawing I posted of the rotor disk, you can see that it is a cylinder magnet that is 1/4" in diameter and just slightly longer that 0.5". My best guess is that it is 9/16" long from the image. The nearest size that KJ Magnetics carries is part number D48. I also recall that Al mentioned on the forum that the magnets were about 0.5" long.
God Bless,
Jason O
CLaNZeR
Quote from: Jdo300
Hi Jason
I think this has remained the same but not 100% sure.
If truthfull as well, he has probably covered this in one of the 1000+ posts across different threads over at the Steorn Forums and I think the repeated questions are wearing himself and OC down. So I do not want to personaly hassle him anymore.
At the end of the day a simple shaft mounted in the base should do and cannot see it being a major issue as long as the design creates the least friction and movement.
Cheers
Sean.
